What factors affect induced voltage and how is it calculated?
The discussion focuses on calculating induced voltage in a nonconservative electric field, specifically addressing the confusion surrounding the definition of voltage between two points. Participants emphasize that induced electromotive force (emf) is determined by the rate of change of magnetic flux (dφ/dt) and that the geometry of the circuit, including the area change, is crucial for inducing emf. The conversation highlights that resistance does not factor into the emf calculation, as it is defined by the open circuit voltage. Additionally, the importance of accurate circuit diagrams is noted, as they can influence the perceived emf.
  • Understanding of electromagnetic induction principles
  • Familiarity with the concept of electromotive force (emf)
  • Knowledge of magnetic flux and its calculation
  • Basic circuit analysis skills
  • Study Faraday's Law of Electromagnetic Induction
  • Learn about the relationship between magnetic flux and induced emf
  • Explore circuit design principles to improve diagram accuracy
  • Investigate the implications of resistance in electrical circuits
Electrical engineers, physics students, and anyone involved in circuit design or analysis will benefit from this discussion, particularly those looking to deepen their understanding of induced voltage and electromagnetic principles.
Fibo112
I am asked to caluculate the induced voltage between the two sides. To me it is confusing what is meant since the field is nonconservative. Is the question phrased in an unclear way or am I missing something about the actual definition of the voltage between two points.
Isn't it just dφ/dt?
That's my first thought on the matter. Are you looking for more than that?
Maybe I was just overthinking it. Usually when I want to figure out the voltage between two points I calculate the work needed to move a charge from one point to the other. Since this is not well defined here I was unsure how to proceed. I guess here since there is only one closed circuit they are talking about the work done when traveling once around this circuit, which is well defined.
edit: they are not asking for the emf for one loop but for traveling from one side to the other, I have to think on this some more
If B is constant then it is necessary for the loop to change area if you want to induce an emf.
this I know
wouldn't the solution here depend the relationship of the resistances of the different components of the loop?
Fibo112 said:
this I know
I thought you did but your comments made me wonder.
The emf is the open circuit volts so resistance doesn't come into it. Each elemental bit of the wire produces a small emf and they all add up to the point ( gap) of interest in the circuit.
I think the original diagram is a bit sloppy (as is common with such diagrams. The emf, measured with two wires to a meter, will depend on the routing of the wires and there are a number of apparent Paradoxes that turn up concerning this. I think that the dφ/dt would be enough to be getting on with here. It's the flux through the area to the right hand side of the grey bar that counts.
There was a thread about this not long ago. You could search for it. There's a Movie of a lecture by Walter Lewin which deals with the apparent paradox.
  • · Replies 42 ·
  • · Replies 21 ·
