Definition of The first law of motion
The discussion centers on the interpretation of Newton's First Law of Motion, specifically the definition stating that "in the absence of forces, a body at rest will stay at rest, and a body moving at a constant velocity in a straight line continues doing so indefinitely." Participants debate whether this definition adequately encompasses non-linear motions, such as circular or orbital movements, exemplified by the Moon's orbit around Earth. The consensus is that while the First Law applies to bodies in motion, it does not account for forces like gravity that influence orbital paths, thus necessitating the Second Law for a complete understanding of satellite motion.
  • Understanding of Newton's Laws of Motion
  • Basic knowledge of gravitational forces
  • Familiarity with circular motion and orbital mechanics
  • Concept of resultant forces and acceleration
  • Study the implications of Newton's Second Law in orbital mechanics
  • Research Kepler's Laws of planetary motion
  • Explore the concept of centripetal force in circular motion
  • Examine case studies of satellite motion and gravitational influences
Students of physics, educators teaching mechanics, and anyone interested in the principles of motion and gravitational effects on celestial bodies.
johsun123
Text book definition is "In the absence of forces, ("body") at rest will stay at rest, and a body moving at a constant velocity in a straight line continues doing so indefinitely".
My thinking.
Moon is orbiting Earth in a circular path, and not in a straight line. Still that motion follows the first law
So shouldn't the definition be
"In the absence of forces, ("body") at rest will stay at rest, and a body in (any state of) motion continues doing so indefinitely".
Non-linear motion also can be subject to 1st law. So why is the bolded terms used in textbook?
I am missing something, Please help me get it.
Science news on Phys.org
"In the absence of forces". In case of the moon, the Earth exerts a force( gravity) to the moon. Thus the velocity changes, orbiting the earth, due to gravity.
It is the same force that pull Newton's apple to Earth and "bend" the moon motion from going in straight line.
I get thet gravity makes moon orbit earth, else it would have gone in a straight line away from earth.
Gravity has acted and moon is now orbiting earth. Even in this state of circular motion, the first law will be applicable( though motion is NOT in a straight line)
1)In the absence of forces, " a body in circular motion " also will continue its circular motion .
2) In the absence of forces "A body in spinning motion" also will continue it spinning motion,
not just the standard test book definition of
In the absence of motion, "a body moving at a constant velocity in a straight line" will coninue its motion.
So isn't the textbook definition about only stright line incomplete?
welcome to pf!
hi johsun123! hiazizlwl! welcome to pf! :smile:
correct :smile:
rubbish! :rolleyes:
where did you get this from?​
azizlwl's analysis is correct :wink:
correct :smile:
rubbish! :rolleyes:
I used circular to mean orbiting motion of planets around sun or moon around earth.
Moon is in a circular motion w r to Earth( due to gravity). Now unless it is acted upon by an asteroid or similar object, will it not continue it's circular(orbiting) motion?
but it's not "in the absence of forces" …
it's in the presence of forces! :smile:
As tiny tim said azizlwl,s analysis is correct.You seem to have contradicted yourself johsun in that you state that "in the absence of forces a body in circular motion also will continue its circular motion" but you also indicate that there is no absence of forces "due to gravity"
So, you cannot apply first law to a satellite oribiting earth, and which is already under influence of gravity?
The second law describes satellite motion.For circular motion there is a resultant force acting towards the centre of the circle(the gravitational force for the moon,planets and other satellites) and the satellite accelerates in the direction of the resultant force.This acceleration is due to the satellite continually changing direction ie at all instants moving tangentially to the circle.
Second law describes satellite motion. Got it.
So can we say, satellite motion cannot be described by first law. If not, why not? Please explain.
The first law describes what happens if there is no resultant force.The object continues doing whatever it happens to be doing.If at rest it will remain at rest.If moving it will continue moving in the same way,in a straight line and at steady speed.
The second law describes what happens if there is a resultant force.It does not remain at rest or move in a straight line at steady speed and therefore it must change speed and/or direction.In other words it accelerates.
Let assume your hypothesis is right. The moon is orbiting the Earth due to 1st. law with added state of orbiting.
Now let take a bigger picture, the solar system.
Why the planets are orbiting at different rate, shown in Keppler's Law.
Maybe they are also obeying "your" first law. How about if the Earth as far as Jupiter from the sun. What speed it will take?
But why there's correlations between orbiting period and mass of the planet.
What they got to do with "your" first law that doesn't say anything about mass?
Newton's 1st law does not mention mass. How big or small the object is, without resultant force it will never move or change direction.
O.K
Thanks.
  • · Replies 16 ·
  • · Replies 41 ·
27K
