Calculating the Y-Component of an Electron's Velocity in a High Voltage Field
To calculate the y-component of an electron's velocity in a high voltage field, the electric field between the plates is determined to be 50,000 V/m. The force acting on the electron is calculated using F = EQ, resulting in a force of 8.01 x 10^-15 N. By applying the work-energy principle, the equation is rearranged to relate the initial and final velocities of the electron. Ultimately, the final y-component of the electron's velocity is found to be approximately 3.617 x 10^7 m/s. This analysis demonstrates the impact of electric fields on charged particles in motion.
pcandrepair
An electron with an initial velocity of 4.7 x 10^7 m/s in the x-direction moves along a trajectory that takes it directly between the center of two 20 cm x 20 cm plates separated by 1 cm. The plates are connected to a high voltage power supply so that the potential difference between them is 500V. What is the magnitude of the y-component of the electron’s velocity when it leaves the plates? (Answer in units of ANSWER x 10^7 m/s.)
E = V/d
I think I found the electric field of the plates to be:
E = 500V / .01m E = 50,000 V/m
From there I have no idea where to go...Any help would be appreciated!
The electric field is going to apply a force to the electron
Do you know the equation that relates electric field, charge, and force?
just started EM stuff now, sorry can't help. but blochwave is right, there is an equation that relates to electric field, charge and force, the only one i can think of uses two particles and a separation between them, would not be useful for in this instance. best of luck. lol I am curious actually...
Well that's the equation FOR an electric field, which you can't quite use here exactly in that form, but he already used the equation for parallel plate capacitors and now KNOWS the electric field, and needs to find the force on a particle with known charge within that (conveniently constant) electric field
If F=EQ, and E=V/d, can you find F? What does Newton's 2nd law say now?
(Hint: the velocity in the x-direction stays constant)
So the force would be F = (50000 V)*(1.602 x10^-19 C)
F = 8.01 x10^-15 N
F = 8.01 x10^-15 N
Yes that is the force. Note that the units of E are either Vm^{-1} or NC^{-1}
Kinetic + potential = Emech
(1/2m(Vi^2)) - q(E)*(Xi) = (1/2m(Vf^2)) - q(E)*(Xf)
Then we changed the equation to this:
qE(20cm) = 1/2(mass of electron)*((Vf^2) + (Vi^2))
Then we solved for Vf:
Vf = 3.61697 x10^7 m/s
  • · Replies 43 ·
  • · Replies 58 ·
  • · Replies 28 ·
