Deflection of Cantilever Beam Arrangement
The discussion focuses on calculating the downward vertical deflection of a cantilever beam arrangement where two beams are fixed at the left-hand side and connected by a prop on the right-hand side. The correct formula for the maximum deflection of the bottom beam is established as (5WL^3)/(48EI), where W is the point load, L is the beam length, E is Young's modulus, and I is the area moment of inertia. The confusion arises from the misapplication of deflection equations and boundary conditions, particularly regarding the placement of the load and the constraints of the beams.
  • Understanding of cantilever beam mechanics
  • Familiarity with deflection formulas in structural engineering
  • Knowledge of Young's modulus (E) and area moment of inertia (I)
  • Ability to apply boundary conditions in beam deflection calculations
  • Study the derivation of beam deflection formulas, particularly for cantilever beams
  • Learn about boundary conditions in structural analysis
  • Explore the effects of different load placements on beam deflection
  • Investigate the application of the general curvature deflection equation in various beam configurations
Structural engineers, civil engineering students, and professionals involved in beam analysis and design will benefit from this discussion, particularly those focusing on cantilever beam arrangements and deflection calculations.
phiska
If two cantilever beams are fixed at Left Hand Side (LHS) and joined to each other by means of a prop at RHS, how do i calculate the downwards vertical deflection of the bottom beam?
The solution i need to prove is (5WL^3)/(48EI)-top deflection.
However, i always seem to get a 7 where there should be a 5!
Any clues as to where i am going wrong?
The beams are of length L, the prop length a.
There is a point force on the bottom beam of magnitude W, downwards, at L/2 m.
I already have calculated the downwards vertical deflection of the top beam to be (d of top)= (PL^3)/(3EI)
Where P= load in prop
EI=constant
Can we see the full question?
A quick guess would be that you've got your constraints wrong on the little link which joins the two beams. Are those supposed to be pin jointed or built in?
It simply states in the question that the distance, a, between the beams is maintained by a prop of diameter, d.
The deflection you stated for the top beam is for a concentrated load at the end of the cantilevered beam, not the mid span.
\delta_m = \frac{Pa^2}{6EI}(3L-a)
Where:
\delta_m = Max deflection
P = Concentrated load at any point of application
a = Distance from cantilever end to load P
L = Total length of beam
E = Young's modulus
I = Area moment of inertia
For your case:
\delta_m = \frac{W(\frac{L}{2})^2}{6EI}(3L-\frac{L}{2})
\delta_m = \frac{WL^2}{24EI}(\frac{6L}{2}-\frac{L}{2})
\delta_m = \frac{6WL^3}{48EI}-\frac{WL^3}{48EI}
\delta_m = \frac{5WL^3}{48EI}
why is it that for the maximum deflection it is (3L-L/2) rather than just (L-L/2)?
I want to understand what is going on as well as getting the correct answer.
Admittedly, that is simply the equation I remember for a cantilever beam with a load anywhere along it's span. I will have to dig up it's derivation later. Give me some time and I'll find it (unless someone else can do it first).
It took me a bit, but I got it (and a nice refresher in beams!):
For the following I use x as the distance from the free end of the beam to the point of load application and P as the load value.
Using the general curvature deflection equation
\frac{d^2y}{dx^2}=\frac{M(x)}{EI}
EI\frac{d^2y}{dx^2}=-Px
EI\frac{dy}{dx}=-\frac{1}{2}Px^2 + C_1
Using the B.C.'s at the cantilever (pt. B) x=L and dy/dx=0 we get:
C_1 =\frac{1}{2}PL^2 and that leads to:
EI\frac{dy}{dx}=-\frac{1}{2}Px^2 +\frac{1}{2}PL^2
EI Y =-\frac{1}{6}Px^3 +\frac{1}{2}PL^2x +C_2
Using the B.C.'s @ pt. B again, we have Y=0 and x=L we get:
C_2 = -\frac{1}{3}PL^3 and that now leads to:
EI Y =-\frac{1}{6}Px^3 +\frac{1}{2}PL^2x -\frac{1}{3}PL^3
We use that equation for the situation of the bottom beam, x=L/2:
EI Y =-\frac{1}{6}P(\frac{L}{2})^3 +\frac{1}{2}PL^2(\frac{L}{2}) -\frac{1}{3}PL^3
After a little algebra...
EI Y = (-\frac{1}{48}+\frac{1}{4}-\frac{1}{3})PL^3
EI Y = (-\frac{1}{48}+\frac{12}{48}-\frac{16}{48})PL^3
Y = -\frac{5PL^3}{48EI}
You can now go back and substitute x=0 for the top beam to get the second part of the deflection for the top beam.
Sorry I took so long.
Thank you so much... you've been really helpful!
