- 595
Kyle-DFW said:I think at this point it might be a good time for you to summarize your conclusions / beliefs / concerns about the experiment in general. Your beliefs regarding my two points of interest mentioned above are obviously what I am most interested in hearing about, but anything else noteworthy is welcome also. Please use the least technical language possible and cite supporting references if possible (even in the German document).
Ok, it might be a bit early in the discussion for the final conclusion, but let me discuss some points that might lead to a better understanding and solve the issues.
At first, I have to point out the spatial coherence topic again as it is most central to any double slit experiment. However that point is somewhat underplayed in basic discussions of the double slit experiment. See for example the following discussion from a different topic in these forums:
https://www.physicsforums.com/showthread.php?t=428319"
Note especially the posts by Andy Resnick, explaining the importance of coherence for any interference pattern and the notion of spatial coherence being a measure of how point-like the source is.
I hope you are familiar with the physics behind the double-slit, but let me paraphrase it. As you are not a scientist, I just want to be sure we are talking about the same issues. The interference pattern arises due to the two fields originating from the two slits. The intensity at any point is given by the squared sum of these fields. As the fields have a phase, those fields can cancel out at a certain position (phases are opposite) or they can add up (equal phase) or anything in between. Now the important point is that these two fields at the slit originate from one common field: The light source placed somewhere in front of the slits. The field from this source travels to the two slits and there is some fixed phase difference between the fields at the slits, which is determined only by the geometry of the experiment. As the phase of the field varies in a sinusoidal manner with the distance between the source and the position of interest, you can calculate the difference between the phases at the two slits without knowing the initial phase at the source. The difference at the slits does not depend on that. This would not work if you used two light sources and placed them in front of each slit. As there is no fixed phase difference between these sources, you will also not get a fixed phase difference at the slits and therefore also no interference pattern.
Now the important point lies in remembering that only the geometry determines the phase difference at the slits. If you consider real light sources, they are not point-like, but have a finite size. Now you can calculate the phase difference at the slits again for a point on one end of the light source and one point on the other end of the light source and will notice that they are slightly different. The phase difference at the slits becomes less well defined and so does the phase difference of the two fields originating from the slits. The interference pattern will become a little bit less visible. What a normal double-slit experiment really measures is exactly the spread in these possible phase differences which can occur at the slit. Basically this is spatial coherence. Maybe it might help if you make a simple sketch of the different situations yourself. It is not really complicated.
To sum up, you need indistinguishable fields originating from two positions with a fixed phase relationship to see an interference pattern. Now there are two possibilities hot to not get such a pattern. You can either not have such a fixed phase relationship (lack of spatial coherence) or you can have distinguishable fields by providing which-way information.
These basics are both necessary to understand the remaining physics behing two-photon interference and DCQE experiments. Was my line of reasoning somewhat clear or should I try to explain it differently? Up to now there is nothing too mysterious involved. This is stuff from a basic optics course. If that point is clear I can continue to tackle the entanglement.
