The discussion revolves around calculating the expected value of a non-standard random variable Y defined as Y = Z^2*exp(Z)/(1 + exp(Z))^2, where Z is a normally distributed random variable. Participants explore various methods for finding E(Y), including the delta method, simulations, and potential approximations, while expressing uncertainty about the existence of a satisfactory solution.
- Exploratory
- Technical explanation
- Debate/contested
- One participant notes that the delta method fails due to accumulating errors and seeks alternative approaches.
- Another participant suggests using simulations to estimate E(Y) instead of seeking an analytical solution, providing R code for implementation.
- A participant expresses a desire for an approximation rather than a numerical solution, indicating that Y exhibits a symmetric bimodal distribution when plotted.
- There is a proposal to consider using the square root of a chi-square distribution as a substitute for the normal distribution, which is argued to be more suitable for the problem.
- One participant questions the validity of the assumption that E(Y) = 0 based on the symmetry of Y(Z) and Z's distribution, but later expresses doubt about this assumption after running simulations.
- Another participant clarifies that while Y(Z) = Y(-Z) holds, it does not imply that E(Y) = 0, as a different condition would be required for that conclusion.
Participants do not reach a consensus on the best method to calculate E(Y). There are multiple competing views regarding the use of simulations, approximations, and the implications of symmetry in the distribution of Y.
Participants acknowledge the absence of an exact analytical solution and express uncertainty about the effectiveness of various proposed methods, including the delta method and Padé approximation. The discussion also highlights the complexity of the distribution of Y and its implications for calculating the expected value.
