Deltafunktion of 4-vectors for energy and momentum coversation
The discussion focuses on the application of the delta function in the context of Compton scattering, specifically demonstrating the equation: \delta(p_{10}+k_1-p_0-k)=p_0\delta(\underline{k}_1(\underline{p}+\underline{k})-\underline{k}\underline{p}). Participants emphasize the importance of dimensional analysis and the correct application of delta function properties, particularly \delta(f(x))=\frac{1}{|f'(x_0)|}\delta(x-x_0). The conversation highlights the need to clarify notation for 4-vectors and the dimensionality of the delta distribution, ultimately leading to a successful derivation of the required relation.
  • Understanding of 4-vectors in physics, specifically electron and photon representations.
  • Familiarity with delta functions and their properties in mathematical physics.
  • Knowledge of Compton scattering and energy-momentum conservation laws.
  • Ability to perform dimensional analysis in physical equations.
  • Study the properties of delta functions in multi-dimensional integrals.
  • Explore the derivation of energy-momentum conservation in particle physics.
  • Learn about kinematic invariants in scattering processes.
  • Investigate the implications of dimensional analysis in theoretical physics.
Physicists, graduate students in particle physics, and anyone involved in theoretical physics research, particularly in the study of scattering processes and the application of delta functions in quantum mechanics.
Ulf
for a compton-scattering-problem, i want to show that:
the momentum- and energy-conversion-law for two particle scattering.
\underline{p}+\underline{k}=\underline{p}_1+\underline{k}_1
relations of kinematic-invariants
\underline{k}\underline{p}=\underline{k}_1\underline{p}_1
\underline{k}_1\underline{p}=\underline{k}\underline{p}_1
\underline{k}_1(\underline{p}+\underline{k})=\underline{k}\underline{p}
here \underline{p} denotes the electron 4-vector \underline{p}=\{p_0,\overline{p}\}, the same for k the 4-vector describing the photon \underline{k}=\{k_0,\overline{k}\}. no subscript and subscribt 1 denote initial and scattered particles respectively.
do i have to use: \delta(f(x))=\frac{1}{|f'(x_0)|}\delta(x-x_0)? but how?
First, it is always a good idea to show explicitely the dimensionality of the \delta distribution, so you want to show
\delta^4(p_{10}+k_1-p_0-k)=p_0\delta^3(\underline{k}_1(\underline{p}+\underline{k})-\underline{k}\underline{p})
Then you already see that both sides are of different dimensionality, so on the right side probably someone integrated without telling you. I would try splitting the \delta distribution, and integrating over \delta(p^0_{10}+k^0_1-p^0_0-k^0) using the on-shell relation \vec{p}² - (p^0)² = m², and similar for the k particle. If your relation is correct, this should work out after some algebra.
first of all: thanks for you answer! the hint to check the dimensions was right. i guess my notation is a bit confusing. so i will choose a new one here in the solution:
\underline{p}=\{p^0,\vec{p}\} and
\underline{k}=\{k^0,\vec{k}\}, where \vec{p} and \vec{k} are the 3-momentum vectors of the electron and the photon respectively. after the scattering we have:
\underline{p}'=\{p^0',\vec{p}'\} and
\underline{k}'=\{k^0',\vec{k}'\}.
so the momentum-energy-law reads:
\underline{p}+\underline{k}=\underline{p}'+\underline{k}'now one can see that both sides of the equation that i want to show are of dim=1.
\delta^{(1)}(p^0'+k^0'-p^0-k^0)=p^0\delta^{(1)}(\underline{k}'(\underline{p}+\underline{k}) -\underline{p}\underline{k}), that is because on the LHS are only the 0-componets, and on the RHS we have scalar-products of 4-vectors, which are also 1-dimensional. now i didnt had to integrate, but to use the formula:
\delta(ax)=\frac{1}{|a|}\delta(x)
in this case p^0=\frac{1}{|a|}. so left to show:
p^0'+k^0'-p^0-k^0=\frac{1}{p^0}(\underline{k}'(\underline{p}+\underline{k}) -\underline{p}\underline{k}) which works out thus the RHS can be written as:
\frac{1}{p^0}(\underline{k}'(\underline{p}+\underline{k}) -\underline{p}'\underline{k}')=\frac{1}{p^0}(k^0'p^0+k^0'k^0-k^0'p^0'-\vec{k}'\vec{p}-\vec{k}'\vec{k}+\vec{k}'\vec{p}')=\frac{1}{p^0}(k^0'p^0+k^0'k^0-k^0'p^0'-\vec{k}'(\vec{p}-\vec{k}+\vec{p}'))
with use of k^0k^0'=p^0p^0' , k^0'p^0'=k^0p^0
\vec{p}+\vec{k}-\vec{p}'=\vec{k}' and ( \vec{k}')^2=(p^0)^2 we get the result.
Very good! So I also got confused by your notation :)
  • · Replies 18 ·
