Proving the Inequality between Lp Norms: A Demonstration for Homework
  • Thread starter Thread starter Telemachus
    Demonstration Norm
The discussion centers on proving the inequality between Lp norms, specifically the relationship between the L2 norm (Euclidean norm) and the L1 norm (Manhattan norm) for a vector x in n-dimensional space. The inequality to prove is ||x||_2 ≤ ||x||_1 ≤ √n ||x||_2. The first part of the proof is established using the triangle inequality, while the second part requires demonstrating that ||x||_1 ≤ √n ||x||_2, which can be approached using the Cauchy-Schwarz inequality. Participants suggest specific strategies, including examining the case for n=2 and leveraging the properties of the norms.
  • Understanding of Lp norms, specifically L1 and L2 norms.
  • Familiarity with the triangle inequality in vector spaces.
  • Knowledge of the Cauchy-Schwarz inequality and its applications.
  • Basic algebraic manipulation and proof techniques in mathematics.
  • Study the Cauchy-Schwarz inequality and its implications for vector norms.
  • Explore the properties of Lp norms in more depth, focusing on their geometric interpretations.
  • Practice proving inequalities involving Lp norms with various examples.
  • Investigate the relationship between different Lp norms and their applications in functional analysis.
Students in mathematics, particularly those studying linear algebra, functional analysis, or optimization, as well as educators looking for examples of norm inequalities in vector spaces.
Telemachus
Hi there. I have to prove this inequality:
##||x||_2 \leq ||x||_1 \leq \sqrt{n} ||x||_2##
Where ##||x||_2## is the ##l_p## norm with p=2, so that:
##||x||_2=(|x_1|^2+|x_2|^2+...+|x_n|^2)^{\frac{1}{2}}##
And similarly ##||x||_1=|x_1|+|x_2|+...+|x_n|## is the ##l_1## vectorial norm.
so, the first part I think its easy (I suspect the second part is also easy, but I couldn't get through it).
I have that:
##||x||_2=(|x_1|^2+|x_2|^2+...+|x_n|^2)^{\frac{1}{2}}\leq |x_1|+|x_2|+...+|x_n|=||x||_1## which is directly satisfied by applying the triangle inequality. So I think that's done.
Now, for the other inequality I have to show that: ##||x||_1 \leq \sqrt{n} ||x||_2##
I couldn't find the way to show that, so I thought that perhaps someone here could help me.
Thanks in advance.
I have that:
Thanks in advance.
Not sure what you mean by follows "directly" from the triangle inequality. I would suggest looking at ##n=2## for ideas. Then it says$$
\sqrt{a^2+b^2}\le |a| + |b| \le \sqrt 2\sqrt{a^2+b^2}$$Square all three sides and see if that gives you any ideas.
I mean that this follows by the triangle inequality: ##\sqrt{a^2+b^2}\leq |a|+|b|##. But what about this: ##|a|+|b|\leq \sqrt{2} \sqrt{a^2+b^2}##? how do I prove that's true? and how do I do that for arbitrary n?
By squaring all sides I get: ##0 \leq 2|ab| \leq a^2+b^2##
I think I see what you meant. I'll try and tell you. Thanks.
So, in general, you need to show that if ##I_n = \{ (i,j): 1 \leq i < j \leq n \}## then
2 \sum_{I_n} |a_i| | a_j| \leq (n-1) \sum a_i^2
The case for ##n = 2## is easy: ##0 \leq (|a|-|b|)^2 = a^2 +b^2 - 2 |a| |b|##.
@Telemachus: Not knowing your background, I wonder if you already have the Cauchy-Schwartz inequality or not:$$
|(\vec x, \vec y)|\le \parallel \vec x \parallel \parallel \vec y \parallel$$where the left side is just the dot product in ##\mathbb R^n## and those are ##l_2## norms on the right. One proof of your right hand inequality is often demonstrated using it.
Yes, I've tried to proove it by using Cauchy Schwartz inequality, but I coulnd't get it. I'll show you:
##| \sum_i x_i y_i | \leq ||x||_2 ||y||_2##
So I have: ##|x_1 y_1+x_2 y_2+...+x_n y_n | \leq \sqrt{ \left ( |x_1|^2+|x_2|^2+...+|x_n|^2 \right )\left ( |y_1|^2+|y_2|^2+...+|y_n|^2 \right ) }##
What I've tried (which is probably not in the right way) was just setting all ##y_i=1 \forall i##. And then I get:
##|x_1+x_2 +...+x_n| \leq \sqrt{n} \sqrt{\left ( |x_1|^2+|x_2|^2+...+|x_n|^2 \right )}=\sqrt{n} ||x||_2##
Which looks close, but I aslo have this:
##|x_1+x_2 +...+x_n| \leq |x_1|+|x_2| +...+|x_n|=||x||_1##
So its still inconclusive.
You are almost there.
Cauchy Schwarz is valid for any choice of ##x_i, y_i##.
You chose ##y_i=1##. Why not also make a specific choice for ##x_i##? (Imagine for a moment that all ##x_i \geq 0##.)
What if your ##\vec x## vector is ##\langle |x_1|,|x_2|,...|x_n|\rangle## in the first place?
Done :D thanks.
  • · Replies 16 ·
