Dennis and Carmen problem with my trial solution , is it right?
  • Thread starter Thread starter nareeman
    trial
The discussion revolves around a physics problem involving two basketballs thrown by Dennis and Carmen from a cliff, one upward and the other downward, both with the same initial speed. The key equation used is v² = v₀² - 2gΔy, where g = -9.8 m/s². It is established that both balls will have the same final speed upon hitting the ground, despite the differing trajectories, due to the conservation of energy principle. The confusion arises from the incorrect application of the initial velocity's sign in the calculations, which is clarified by emphasizing that squaring the initial velocity negates the sign.
  • Understanding of kinematic equations in physics
  • Familiarity with the concept of gravitational acceleration (g = -9.8 m/s²)
  • Knowledge of conservation of energy principles
  • Ability to manipulate algebraic equations
  • Study the derivation and application of kinematic equations in physics
  • Learn about the conservation of energy and its implications in projectile motion
  • Practice solving problems involving vertical motion under gravity
  • Explore the effects of initial velocity on the trajectory of projectiles
Students studying physics, particularly those focusing on kinematics and projectile motion, as well as educators looking for examples of common misconceptions in these topics.
nareeman
Dennis and Carmen are standing on the edge of a cliff. Dennis throws a basketball vertically upward, and at the same time Carmen throws a basketball vertically downward with the same initial speed. You are standing below the cliff observing this strange behavior. Whose ball is moving fastest when it hits the ground?
v^2 = v0^2 -2gΔy
in the same speed cause when Dennis basketball back to the initial position "`the throwing position" it will back with the same initial speed with different direction "the same direction as Carmen" so it's the same but it'll take Dennis basketball more time
Dennis
v0 is +
v^2 =+v0^2 -2gΔy
Carmen
v0 is -
v^2 =-v0^2 -2gΔy
g =-9.8 for both
Δy is the same for both
so
Dennis v^2 =+v0^2
Carmen v^2 =-v0^2
add them
v^2+v^2 =0
v^2 =-v^2
please tell me if that's right if not how it can be solve
thank you:smile:
v^2 = v0^2 -2gΔy
Your logic is correct :approve:
Dennis
v0 is +
v^2 =+v0^2 -2gΔy
Carmen
v0 is -
v^2 =-v0^2 -2gΔy
Careful, the formula wants you to square the initial velocity. Carmen's initial velocity is -v0, and squared is (-v0)(-v0) = +v02.
As you can see, the initial velocity being negative does not change the result.
g =-9.8 for both
so
Dennis v^2 =+v0^2
Carmen v^2 =-v0^2
add them
v^2+v^2 =0
v^2 =-v^2
If you consider that last line of math it represents an impossible situation, since you can't have any real number squared that turns out negative. The glitch can be traced back to squaring the initial velocity as I pointed out above.
You could also have used a conservation of energy approach (if you've covered that yet in your course).
thank you ,we have not cover it yet
so if I'm going to answer for that question in the exam i just write this formula "v^2 = v0^2 -2gΔy" and say
everything is the same for both cases " v0^2 -2gΔy"
then the final speed is the same
only or should i add something else ?
Forget the math for a minute and just think about it this way. If the ball thrown upward has an initial velocity X, then when it gets back to the same point on its way down, what is its velocity at that point?
That's all you really need :smile:
the same initial velocity that was it thrown with
  • · Replies 23 ·
