Can Increasing Helium Density Affect Payload in Space?
Increasing the density of helium does not result in a greater payload capacity for a balloon in space. The discussion revolves around Archimedes' principle, which states that the buoyant force acting on an object submerged in a fluid is equal to the weight of the fluid displaced. The calculations presented indicate that the buoyant force generated by air density (1.29 kg/m³) and the volume of the spherical body (radius 7.15 m) leads to a maximum payload calculation that ultimately reveals a sign error in the buoyancy force equation.
  • Understanding of Archimedes' principle
  • Basic knowledge of buoyancy and fluid mechanics
  • Familiarity with density calculations
  • Ability to perform weight and force calculations
  • Study Archimedes' principle in detail
  • Learn about buoyancy forces in different fluids
  • Explore the effects of gas density on payload capacity in aerospace applications
  • Review calculations involving weight, density, and volume
Aerospace engineers, physics students, and anyone interested in the principles of buoyancy and payload calculations in fluid dynamics.
MrInventive
New poster has been reminded to show the Relevant Equations and their work on the solution.
A spherical balloon has a radius of 7.15 m and is filled with helium. How large a cargo can it lift, assuming that the skin and structure of the balloon have a mass of 930 kg? Neglect the buoyant force on the cargo volume itself.
p =m/v density
P = F/A
F = ma
I don't even know where to start...
could you please show me step by step
What does Archimedes' principle state?
It's customary that you show an attempt before any more help can be given.
Let me give you some hint. Air will act as a fluid, you don’t have to neglect the effect of air as we normally do in mechanics problem.
Can you solve this question: A spherical body of radius ##7.15~m## and mass ##930 ~kg## is in equilibrium inside the water. What are the forces acting on the sphere?
The Atmosphere and gravity because of the mass of both the fluid and the balloon
Hello Sorry for the late delay...I lost the website. here's my work
Ok, that's a diagram, but please state Archimedes' principle.
If an any object is in a fluid (or partially )... there is a buoyant force that will push it...this force is equal to the amount of that liquid displaced.
What do you mean by amount?
It is equal to the weight of the fluid displaced.
Ok, so what fluid is being displaced by the balloon and what is its weight?
well I guess its in air so...that's about it. its density is 1.29 kg/m^3
weight is m*g
m = pV...i get lost here
weight is m*g
You seem to have all the pieces. You know the volume of air displaced, its density, and the equations leading to its weight. Just put it all together.
Be careful about helium's density and its units. I would advise you to check on your textbook about both density and Archimedes principle concepts.
ok...i'll try
Thank you...i'll look at that
MrInventive said:
ok...i'll try
I hope this is adequate... I have more questions by the way. Is it OK if i post them?
hy.
buoyancy force = air dencity*spher volum*gravity const=1.15*1530*9.8=15000 n
weight force= m*9.8 = 930*9.8=9115 n
helume wight - neglebl
max weight can be load= (15000-9115)/9.8=600 kg
You have a sign error. It should be obvious that increasing the density of helium will not result in a greater payload.
In addition, you seem to have a numerical error somewhere in the final step, but I cannot tell where it is.
