Derivating a sum weird result. wtf
  • Thread starter Thread starter sh86
    Sum Weird
The discussion revolves around a derivative problem involving the summation of a variable, specifically examining the expression \(\frac{d}{dx}\sum_{i=1}^x x\) and its implications. Participants are exploring the relationship between discrete summation and continuous differentiation, questioning the validity of treating \(x\) as both a variable and an upper limit in the summation.
  • Participants are questioning the interpretation of \(x\) in the context of the summation and its role as a variable versus a limit. They discuss the implications of differentiating a sum that is defined over integers and how that affects the application of derivatives.
The conversation is active, with participants providing differing viewpoints on the nature of \(x\) in the summation and its implications for differentiation. Some suggest that the summation's upper limit being a non-integer complicates the differentiation process, while others explore alternative representations to address this issue.
There is an ongoing debate about the appropriateness of applying derivatives to sums defined over discrete values, particularly when the upper limit is not an integer. Participants are also considering the implications of treating \(x\) as both a variable and a limit in the context of calculus.
sh86
Hey I was doing a standard derivative problem but I ran into something somewhat strange. Check it out:
\frac{d}{dx}\sum_{i=1}^xx=\frac{d}{dx}x^2=2x
Okay, simple enough..but what if I write it like this?
\frac{d}{dx}\sum_{i=1}^xx=\frac{d}{dx}(x+x+...+x)=1+1+...+1=x.
Why am I getting two different answers?
x^2 \neq \sum^x x. This definition of x^2 does not make sense. d/dx does not just apply to whole numbers for x. It applies to all real numbers of x.
In that definition for x^2 which you have as a sum. x is not a variable, it's the last term of your series.
I don't get it. Are you saying that because x is the upper bound of the summation that means it's limited to nonnegative integers and because of that, you can't take the derivative?
How's it not a variable? I looked up the definition on Mathworld.com:
A variable is a symbol on whose value a function, polynomial, etc., depends.
and x can take on different values (0, 1, 2, etc.) and the function f(x)=\sum_{i=1}^x x depends on it.
Derivatives are defined for functions of a continuous variable. Since x is a discrete, integer variable in your summation, it doesn't make any sense to differentiate with respect to x here.
If you don't understand my answer, I'll ask you this question: what is that sum for, say, x=3.5?
Another way of looking at it: in x+ x+ x+ x+\cdot\cdot\cdot+ x, "x times", the "x times" is itself a function of x- this can't be treated like you would x added to itself a fixed number of times. Just as the derivative of x^x is nothing like the derivative of x^n for fixed n.
Just to add something to Halls's post, you can get round the fact that the x above the summation sign 'ought' to be an integer, by replacing it with, say, floor(x). But the analysis you use in your argument doesn't allow for the fact that the upper summation limit varies with x - you differentiated within the summation sign, but ignored the x (or floor(x)) appearing above it.
  • · Replies 24 ·
