Derivation: Entropy of Vaporisation using Redlich-Kwong EoS
Tom Hardy
For some reason it is not letting me add the image here, here is the link to the question:
http://imgur.com/a/3DLWM
The part I'm stuck on is the last part. Basically, the question is to obtain the following equation for the entropy of vaporisation using the Redlich-Kwong equation:
\Delta S = R\Bigg[ \ln \frac{V_2 -b}{V_1 - b} \Bigg] + \frac{0.5a}{bT^{1.5}}\ln \Bigg[ \frac{V_2(V_1-b)}{V_1(V_2-b)} \Bigg]
P = \frac{RT}{V-b} - \frac{a}{T^{0.5}V(V+b)}
I think I should start by using the known fact that at equilibrium, the free energy of both phases must be the same. Using Gibbs free energy:
dG = -SdT + VdP \implies -S_1dT + V_1dP = -S_2dT + V_2dP
Therefore, I can write an equation for change in entropy due to vaporisation:
S_1 - S_2 = (V_1 - V_2)\frac{dP}{dT}
However when I simply differentiate the given EoS and multiply by $V_1 - V_2$ I don't get the same result. Clearly, in the answer they have integrated wrt v at some point but I just don't get why or how. Any help will be appreciated, thank you.
We can't just take the derivative of P wrt to T since P is also a function of V, unless we would assume V to be constant, which would be unusual for vaporization.
Instead we can write dU=TdS=PdV for a reversible path.
If we assume isothermal vaporization, we get ##T\Delta S=\int PdV##, from which the equation follows.
Likes Greg Bernhardt and Tom Hardy
Thank you, my only concern is the limits of integration. Seemingly, the lower is limit is the liquid phase volume, but how can we use this with the EoS that is only valid for gases?
