Derivation of the energy principle from Gregory Classical Mechanics textbook
The discussion focuses on the derivation of energy conservation in a system of N particles as presented in Gregory's Classical Mechanics textbook. The key equation discussed is the total work done by external forces, expressed as the integral of force over time equating to the difference in potential energy at two points. The participants clarify that transitioning from a time integral to a position integral is valid due to the path independence of conservative forces, affirming that potential energy is indeed time independent.
  • Understanding of classical mechanics principles, particularly energy conservation.
  • Familiarity with vector calculus, specifically gradient operations.
  • Knowledge of conservative forces and potential energy concepts.
  • Ability to interpret integrals in the context of physics.
  • Study the derivation of energy conservation in classical mechanics using Gregory's Classical Mechanics textbook.
  • Learn about the properties of conservative forces and their implications in physics.
  • Explore vector calculus applications in physics, focusing on gradients and integrals.
  • Investigate the relationship between time and position integrals in the context of conservative systems.
Students of classical mechanics, physics educators, and anyone interested in the mathematical foundations of energy conservation principles.
zackiechan
I'm working through Gregory's Classical Mechanics and came across his derivation of energy conservation for a system of N particles that is unconstrained. We get to assume all the external forces are conservative, so we can write them as the gradient of a potential energy. There's a step he makes in the derivation that has me confused.
By Gregory, the total work done by all the external forces (that's the Fis ) is:
$$\sum_{i=1}^{N} \int_{t_A}^{t_B} \vec{F_i} \cdot \vec{v_i} dt = \sum_{i=1}^{N} (\phi_i(\vec{r_A}) - \phi_i(\vec{r_B})) $$
What I don't understand is how to go from the integral:
$$\int_{t_A}^{t_B} \vec{F_i} \cdot \vec{v_i} dt$$ to the potentials.
My idea is:
$$\int_{t_A}^{t_B} \vec{F_i} \cdot \vec{v_i} dt = \int_{t_A}^{t_B} -\nabla \phi_i \cdot \vec{v_i} dt = \int_{\vec{r_A}}^{\vec{r_B}} -\nabla \phi_i \cdot \vec{dr} = \phi_i(\vec{r_A}) - \phi_i(\vec{r_B})$$
My questions are :
Can we go from a time integral to a position integral without messing with the potentials? I know they are path independent, but are they time independent?
Does integrating from tA to tB do the same sum as integrating from rA to rB?
If they were not time independent you would typically induce energy into the system simply by the change in potential.
Yes. The path taken is just a particular parametrisation of a path from A to B.
Thank you very much for the response. I really like the logic behind the potentials being time independent!
