Derivative discretization with fixed boundary condition
The discussion revolves around the discretization of derivatives in the context of partial differential equations (PDEs) with fixed boundary conditions. Participants explore methods for calculating spatial derivatives at the boundaries while maintaining accuracy, particularly in a one-dimensional domain.
  • One participant inquires about the appropriateness of using different discretization methods (forward/backward differences) at the boundaries while employing central differences within the domain.
  • Another participant notes that using forward or backward differences at the boundary results in first-order accuracy, contrasting with the second-order accuracy of central differences used in the interior.
  • A suggestion is made to use a fictitious point outside the domain to maintain second-order accuracy at the boundary when applying central differences.
  • A participant describes their specific discretization schemes for calculating the derivative at the boundaries, asserting that all methods are second-order accurate.
  • Concerns are raised about the use of ghost points when no specific boundary condition is provided for the derivative, leading to uncertainty about the values to assign to these points.
  • Another participant discusses a different scenario where the boundary condition specifies zero derivative, indicating a potential use of ghost points to maintain accuracy.
  • There is a discussion about the need for additional information regarding the derivative of a function at the boundaries when applying certain methods.
  • One participant acknowledges the need to clarify their understanding of the boundary conditions and the implications for their calculations.
  • Another participant suggests that ghost points can be incorporated into the finite difference equations to improve accuracy, though the effectiveness may depend on the specific problem.
Participants express differing views on the best approach to discretizing derivatives at the boundaries, with no clear consensus reached on the optimal method. Some agree on the use of ghost points under certain conditions, while others remain uncertain about their applicability in the absence of specific boundary conditions for derivatives.
Participants highlight limitations in their current understanding of boundary conditions and the implications for their discretization methods. There is also mention of the accuracy of different finite difference methods, but no resolutions are provided regarding the best practices for specific scenarios.
debsankar
Hi all,
It may be a trivial question. But, if I have a PDE of variable u(x,t)
[itex]\dot{u} = f(u,\partial_x{u},..)[/itex]
with boundary condition :
[itex]u(0,t) = u(L,t) =0.[/itex]
Now I need to calculate
[itex]\partial_x{u}[/itex]
for that can I define the discretisation differently only on the boundary (forward / backward)?
And inside the domain(1D) I am using central difference for the perpose.
Does doing this introduce any inconsistencies in the process? Or if there is any other
standard method of doing this...
please let me know.
Regards.
Yes, that's a basic problem with finite difference methods.
The difference estimates of the derivative at the interior points are second-order accurate. If you take a forwards or backwards difference using two grid points at the boundary, that is only first order accurate.
See here for better ways to do it: http://www.scientificpython.net/1/p...-finite-differences-three-different-ways.html (these should be in any good book on FD methods).
One way of doing this is to use a fictitious point at L + Δx in the discretized central difference version of the partial derivative of u with respect to x in the boundary condition. You then substitute this discretized relationship involving the fictitious point into your discretized PDE. This preserves the second order accuracy at the boundary.
@ AlephZero >>
Thanks for the reference. I will describe a bit what I did for the completeness of the thread and also to
clear misconceptions if I have got any in this regard.
To calculate [itex]\partial_x{u}[/itex] at boundaries I use >>
[itex]\partial_x{u} = \frac{-u(x+2h)+4u(x+h)-3u(x)}{2h} + O(h^2)[/itex] at x=0
and
[itex]\partial_x{u} = \frac{3u(x)-4u(x-h)+u(x-2h)}{2h} + O(h^2)[/itex] at x=L
and
[itex]\partial_x{u} = \frac{u(x+h)-u(x-h)}{2h} + O(h^2)[/itex] for all 0<x<L
So all the discretization schemes are now second order accurate.
@Chestermiller >>
The 'ghost' points you refer to is useful if I have a condition like >> [itex]\partial_x{u} =0[/itex]. But for the mentioned case its not clear to me what values I should take at the ghost points? because I don't have any condition on boundary value of the derivative. So I think
using second order forward and backward FD at the boundaries with first order central FD inside
is appropriate. Please let me know if I am missing something.
Regards,
Deb.
debsankar said:
@ AlephZero >>
and
and
@Chestermiller >>
Regards,
Deb.
To answer this question, I need to know more about the boundary conditions at the two ends. What are the boundary conditions in your particular problem?
du/dt=f(u,du/dx,..)
u(0,t)=u(L,t)=0.
This is the problem the thread started with.
Regards.
Regards.
I'm sorry. I didn't read your original post carefully enough. I totally agree with what AlephZero said regarding using one sided difference formulas to get the normal derivative to second order accuracy.
Chet
Also there is another small confusion..
say I have an eq like this >>
[itex]\dot{u} = \partial_x{f(\partial_x{u})}[/itex]
and if my BC now is >>
[itex]\partial_x{u} = 0[/itex] at both ends for all time.
Now I will use the 'ghost point' method to calculate du/dx at the ends.
I will just make(in case i use central FD) >>
u(-1)=u(1) and u(n-1) = u(n+1)
this will give me du/dx =0 on boundary(i.e. for u(0) and u(n)) all the time.
But when I again calculate df/dx I will use the previously discussed method >>
@ AlephZero >>
To calculate ∂xu at boundaries I use >>
[itex] <br /> \partial_x{u}=[−u(x+2h)+4u(x+h)−3u(x)]/2h +O(h^2) at x=0 \\<br /> and \\<br /> \partial_x{u}=[3u(x)−4u(x−h)+u(x−2h)]/2h +O(h^2) at x=L \\<br /> and \\<br /> \partial_x{u}=[u(x+h)−u(x−h)]/2h +O(h^2) for all 0<x<L \\<br /> [/itex]
because, I cannot use ghost points for 'f' as I do not have the information of df/dx
at boundaries. Am I right?
If you are specifying df/dx at the boundary, then you know df/dx. But please do me a favor. Write out your DF approximation to the rhs of your pde above for point n, taking into account the zero flux boundary condition.
Chet
@ Chestermiller
I will get back to this tomorrow, I got what you said...
actually you are right I also have df/dx values at boundary...as I have du/dx.
I will explain in details my equations and what I am getting.
goodbye till then.
You don't need to make that assumption.
You can write two equations that include the "ghost point". One is the finite difference approximation to your PDE at the boundary point. The other is the finite difference approximation for the derivative at the boundary.
Then, you can eliminate the ghost point from those two equations algebraically, or you can solve the problem numerically including both the ghost points and the extra equations.
That is the third method in the link I gave. It may or may not give "better answers" than the second method - it depends on the particular equation and boundary conditions. (The link seems to say the third method will always give better answers than the second - but I'm not convinced about that).
  • · Replies 22 ·
  • · Replies 17 ·
