How to Derive the Dual Frame Vector in Terms of Connection Components?
The discussion focuses on deriving the derivative of a dual frame vector in terms of connection components using the relation between the dual frame vectors. The key equation presented is the application of the Leibniz rule, leading to the expression for the derivative, which involves the connection coefficients. There is confusion regarding the distinction between the derivatives of dual basis vectors and tangent basis vectors. The participant expresses uncertainty about how to incorporate connection components without relying on prior definitions. The conversation emphasizes the importance of correctly applying the mathematical principles to derive the desired expression.
BOAS
Use the relation ##\langle \vec e^a, \vec e_b \rangle = \delta^a_b## and the Leibniz rule to give an expression for the derivative of a dual frame vector ##\frac{\partial \vec e_b}{\partial x^a}## in terms of the connexion components.
I'm not sure how to do this, but this is what I've got so far:
##\partial_c \langle \vec e^a, \vec e_b \rangle = 0##
##\langle \partial_c \vec e^a, \vec e_b \rangle + \langle \vec e^a, \partial_c \vec e_b \rangle = 0##
##\langle -\Gamma^b_{dc} \vec e^d, \vec e_b \rangle + \langle \vec e^a, \Gamma^d_{bc} \vec e_d \rangle = 0##
##\Gamma^d_{bc}\langle \vec e^a, \vec e_d \rangle - \Gamma^b_{dc} \langle \vec e^d, \vec e_b \rangle = 0##
Between these lines you are using what you are supposed to show ...
##\frac{\partial \vec e_b}{\partial x^a} = \Gamma^c_{ba} \vec e_c## was presented as a definition to me, so I'm not sure how I can bring in the connection components without using that fact. (Though I do appreciate your point)
That is not the derivative of the dual basis vector, it is the derivative of the tangent basis vector.
  • · Replies 32 ·
  • · Replies 27 ·
