Derivative of a integral function?
The discussion focuses on finding the derivative of an integral function, specifically \(\frac{d}{dx}\int^x_y f(x,u)du\). It highlights that under certain assumptions, this can be expressed as \(f(x,x) + \int^x_y \frac{d}{dx}f(x,u)du\). The participants reference Lagrange's formula for derivatives of integrals with variable limits, noting that in this case, \(y\) is treated as a constant since it does not depend on \(x\) or \(u\). This leads to the conclusion that the derivative simplifies due to the independence of \(y\). The discussion provides clarity on how to combine these concepts effectively.
pellman
How does one work the following?
I know that (given certain assumptions about the function f)
\frac{d}{dx}\int^x_y f(w,u)du=f(w,x)
and
\frac{d}{dx}\int^c_y f(x,u)du=\int^c_y \frac{df}{dx}(x,u)du
but how do we put them together?
Mathematics news on Phys.org
<br /> \frac{d}{dx}\int^x_y f(x,u)du = \int^x_y \frac{d}{dx}f(x,u)du+f(x,x). <br />
Thanks, Pere.
In general, Lagrange's formula:
\frac{d}{dx}\int_{\alpha(x)}^{\beta(x)} f(x,t)dt= f(x,\beta(x))\frac{d\beta}{dx}- f(x, \alpha(x))\frac{d\alpha}{dx}+ \int_{\alpha(x)}^{\beta(x)} \frac{\partial f}{\partial x} dt
In this particular problem y is independent of both x and u and can be treated as a constant: dy/dx= 0.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
