Derivative of cosh x: Clarifying Confusion
  • Context: Undergrad
  • Thread starter Thread starter Michael_Light
    Derivative
The discussion revolves around the derivative of the hyperbolic cosine function, cosh(x), and clarifications regarding the transition between different representations of this derivative. Participants explore the implications of different definitions of cosh(x) and the mathematical steps involved in deriving its derivative.
  • One participant questions whether the index for summation should start at k=0 instead of k=1, suggesting confusion about the terms involved.
  • Another participant argues that the k=0 term does not contribute to the sum since it results in a value of 0, thus justifying starting the index at k=1.
  • A third participant provides a reformulation of the sum, showing how to rewrite the expression for the derivative of cosh(x) using factorials and changing the index of summation.
  • Some participants express that defining cosh(x) as (e^x + e^{-x})/2 is a more straightforward approach to finding its derivative compared to the power series definition.
  • There is a suggestion that the method of deriving the derivative from the power series is valid but may seem unnecessarily complex compared to the exponential definition.
Participants do not reach a consensus on the best approach to derive the derivative of cosh(x). There are competing views regarding the clarity and efficiency of different definitions and methods.
Some assumptions about the definitions of cosh(x) are not explicitly stated, and there are unresolved steps in the mathematical reasoning presented, particularly in the transition between summation indices.
Michael_Light
Hi... I read this from my lecture note, but i couldn't understand:
i) the red part, shouldn't it be k =0 instead of k=1?
ii) the third line to the fourth line... i.e.
I have no idea how to change from the third line to the fourth line..
Can anyone enlighten me? Thanks a lot.. :smile:
It doesn't matter. Since the terms being summed have a factor of "k", the k= 0 term has value 0.
In general, for power series, [itex]f(x)= \sum_{k=0}^\infty a_kx^k[/itex], the derivative can be written as either [itex]f'(x)= \sum_{k=0}^\infty ka_kx^{k- 1}[/itex] or as [itex]f'(x)= \sum_{k=1}^\infty ka_kx^{k- 1}[/itex] because the k= 0 term is 0.
By making the change of index, n= k- 1, so that k= n+1, the second can be written [itex]f'(x)= \sum_{n=0} (n+1)a_{n+1}x^n[/itex].
The first sum can be rewritten as
[itex]\displaystyle \sum_{k=1}^\infty (2k)\frac{x^{2k-1}}{(2k)!}=\sum_{k=1}^\infty \frac{x^{2k-1}}{(2k-1)!}[/itex]​
since [itex](2k)!=(2k)(2k-1)![/itex]. To change the base index, replace [itex]k[/itex] by [itex]k+1[/itex]. You then get the sum
[itex]\displaystyle \sum_{k=0}^\infty \frac{x^{2k+1}}{(2k+1)!}.[/itex]​
This seems to be a very roundabout way of getting this result.
cosh(x) = (ex + e-x)/2
The derivative = (ex - e-x)/2 =sinh(x).
IF cosh(x) has been defined as [itex](e^x+ e^{-x})/2[/itex], yes, that is more direct. However, if cosh(x) has been defined as [itex]\sum_{i=0}^\infty x^{2i}/(2i)![/itex], as is quite possible and apparently as done in the first post, the argument given is more direct.
  • · Replies 29 ·
  • · Replies 36 ·
