Calculating Derivative of Integral w/ Chain Rule
  • Context: MHB
  • Thread starter Thread starter mathmari
    Derivative Integral
The discussion focuses on calculating the derivative of the integral function $$F(x)=\int_{g(x)}^{h(x)}f(x,y)\, dy$$ using the chain rule. Participants clarify the definitions of the functions involved, specifically $G:I\rightarrow \mathbb{R}^3$ and $H:J\times J\times I\rightarrow \mathbb{R}$, and derive the expression for $F'(x)$ as $$F'(x)=H'(G(x))\cdot G'(x)$$. The final expression for the derivative incorporates Leibniz's rule, leading to $$F'(x) = -f(x, g(x))\cdot g'(x) + f(x, h(x))\cdot h'(x) + \int_{g(x)}^{h(x)}f_x(x,h(x))\, dy$$, confirming the accuracy of the calculations and interpretations presented.
  • Understanding of the chain rule in calculus
  • Familiarity with partial derivatives and total differentials
  • Knowledge of integral calculus, specifically Leibniz's rule
  • Experience with differentiable functions and vector calculus
  • Study Leibniz's rule for differentiating under the integral sign
  • Explore the application of the chain rule in multivariable calculus
  • Learn about the properties of continuous and differentiable functions
  • Investigate the implications of partial derivatives in vector functions
Mathematicians, calculus students, and educators seeking to deepen their understanding of differentiation techniques involving integrals and the chain rule.
mathmari
MHB
Hey! :o
Let $I=[a,b]$, $J=[c,d]$ compact intervals in $\mathbb{R}$, $g,h:I\rightarrow J$ differentiable, $fI\times J\rightarrow \mathbb{R}$ continuous and partial differentiable as for the first variable with continuous partial derivative.
Let $F:I\rightarrow \mathbb{R}$.
I want to calculate the derivative of $$F(x)=\int_{g(x)}^{h(x)}f(x,y)\, dy$$ using the chain rule.
Following hint is given:
Let $G:I\rightarrow \mathbb{R}^3$ and $H:J\times J\times I\rightarrow \mathbb{R}$ defined by $G(x):=(g(x), h(x), x)=(u,v,w)$ and $H(u,v,w):=\int_u^vf(w,y)\, dy$. Then it is $F=H\circ G$. So, to calculate the derivative of the integral we have to calculate the derivative of $F(x)=H(G(x))$.
From the chain rule we have that $F'(x)=H'(G(x))\cdot G'(x)$.
The derivatives of the functions $H$ and $G$ are the following:
\begin{align*}G'(x)&=\frac{dG(x)}{dx}=\frac{dG(x)}{dg(x)}\cdot \frac{dg(x)}{dx}+\frac{dG(x)}{dh(x)}\cdot \frac{dh(x)}{dx}+\frac{dG(x)}{x}\cdot \frac{dx}{dx}\\ & =\frac{dG(x)}{dg(x)}\cdot \frac{dg(x)}{dx}+\frac{dG(x)}{dh(x)}\cdot \frac{dh(x)}{dx}+\frac{dG(x)}{x}\end{align*} The last term $\frac{dG(x)}{x}$ is not the same as $G'(x)$, is it?
For the derivative of $H$ do we use the total differential?
Or am I thinking wrong? (Wondering)
Hey mathmari! (Wave)
Isn't in general the derivative of a vector function $\phi$ of multiple variables the matrix:
$$\phi'(x) = \left(\pd {\phi_i} {x_j}\right)$$
(Wondering)
So isn't it:
$$G'(x) = \begin{pmatrix}g(x)\\h(x)\\x\end{pmatrix}' = \begin{pmatrix}g'(x) \\h'(x)\\ 1\end{pmatrix}$$
Shouldn't it then be:
$$H'(u,v,w) = \left(\pd {H}{u}\quad \pd {H}{v}\quad \pd {H}{w}\right)$$
(Wondering)
(Wondering)
So isn't it:
$$H'(u,v,w) = \left(\pd {H}{u} \pd {H}{v} \pd {H}{w}\right)$$
(Wondering)
At the derivative of $H$ you mean it as a vector, or not? (Wondering) Oh ok!
So, so we have the following?
\begin{align*}F'(x)=H'(G(x))\cdot G'(x)= \left(\pd {H}{g(x)} \pd {H}{h(x)} \pd {H}{x}\right)\cdot \begin{pmatrix}g'(x) \\h'(x)\\ 1\end{pmatrix}= \pd{H}{g(x)}\cdot g'(x)+ \pd {H}{h(x)}\cdot h'(x)+\pd {H}{x}\cdot 1\end{align*} (Wondering)
I meant it as the transpose of a vector (a row vector).
To be fair, there are different schools of thought whether it's a vector, a row vector, or a column vector.
However, we should be consistent to make sure we correctly multiply with another vector or matrix. (Nerd)
mathmari said:
Oh ok!
Almost.
But instead of $\pd H{g(x)}$ we should have $\pd Hu(g(x),h(x),x)$. (Worried)
That is, we can't take a partial derivative with respect to $g(x)$. We can only take a partial derivative with respect to a variable. In our case the variable is $u$ and not $g(x)$.
Then, after taking the partial derivative, we should substitute $G(x)=(g(x),h(x),x)$. After all, $\pd Hu$ is a scalar function of 3 variables. (Nerd)
Ah ok!
I thought about that again. (Thinking)
Do we have from the chain rule that $F'(x)=\frac{H(G(x))}{dx}=\nabla H(G(x))\cdot G'(x)$ ? (Wondering)
The derivative of the vector function $G$ is \begin{equation*}G'(x) = \begin{pmatrix}g(x)\\h(x)\\x\end{pmatrix}' = \begin{pmatrix}g'(x) \\h'(x)\\ 1\end{pmatrix}\end{equation*}
The gradient of the function $H$ is equal to \begin{equation*}\nabla H= \left(\frac{\partial{H}}{\partial{u}} \ \ \ \frac{\partial{H}}{\partial{v}} \ \ \ \frac{\partial{H}}{\partial{w}}\right)\end{equation*} At the point $G(x)$ the gradient is equal to \begin{equation*}\nabla H(G(x))= \left(\frac{\partial{H}}{\partial{u}}(g(x), h(x), x) \ \ \ \frac{\partial{H}}{\partial{v}}(g(x), h(x), x) \ \ \ \frac{\partial{H}}{\partial{w}}(g(x), h(x), x)\right)\end{equation*}
So we get:
\begin{align*}F'(x)&=\nabla H(G(x))\cdot G'(x)\\ & =\left(\frac{\partial{H}}{\partial{u}}(g(x), h(x), x) \ \ \ \frac{\partial{H}}{\partial{v}}(g(x), h(x), x) \ \ \ \frac{\partial{H}}{\partial{w}}(g(x), h(x), x)\right)\cdot \begin{pmatrix}g'(x) \\h'(x)\\ 1\end{pmatrix} \\ & = \frac{\partial{H}}{\partial{u}}(g(x), h(x), x)\cdot g'(x)+\frac{\partial{H}}{\partial{v}}(g(x), h(x), x)\cdot h'(x)+\frac{\partial{H}}{\partial{w}}(g(x), h(x), x)\end{align*}
The derivative of an integral in respect to its upper limit is identical to the value of the integral at the upper limit, accordint to the differential and integral calculus, right? (Wondering)
So, we have that $\displaystyle{\frac{\partial{H}}{\partial{u}}(u,v,w)=\frac{\partial}{\partial{u}}\left (\int_u^vf(w,y)\, dy\right )=f(w,u)}$ and $\displaystyle{\frac{\partial{H}}{\partial{v}}(u,v,w)=\frac{\partial}{\partial{v}}\left (\int_u^vf(w,y)\, dy\right )=\frac{\partial}{\partial{v}}\left (-\int_v^uf(w,y)\, dy\right )=-\frac{\partial}{\partial{v}}\left (\int_v^uf(w,y)\, dy\right )=-f(w,v)}$.
We also have that $\displaystyle{\frac{\partial{H}}{\partial{w}}(u,v,w)=\frac{\partial}{\partial{w}}\left (\int_u^vf(w,y)\, dy\right )=\int_u^v\frac{\partial}{\partial{w}}f(w,y)\, dy=\int_u^vf_w(w,y)\, dy}$.
Therefore, we get:
\begin{equation*}F'(x) = f(x, g(x))\cdot g'(x)-f(x, h(x))\cdot h'(x)+\int_{g(x)}^{h(x)}f_x(x,h(x))\, dy\end{equation*} Is everything correct? (Wondering)
Indeed. The gradient is the same as the derivative.
Let's see... suppose we integrate $\phi$ with anti-derivative $\Phi$, followed by differentiating with respect to the lower bound $u$.
Then:
$$\pd {}u \int_u^v \phi(x)dx = \pd{}u[ \Phi(v) - \Phi(u)] = -\phi(u)$$
isn't it? (Wondering)
I think it should be $-f(w,u)$. (Thinking)
Therefore, we get:
I think that a plus and minus sign should be exchanged. (Worried)
Then:
Oh yes (Tmi)
We have that $\displaystyle{\frac{\partial{H}}{\partial{u}}(u,v,w)=\frac{\partial}{\partial{u}}\left (\int_u^vf(w,y)\, dy\right )=\frac{\partial}{\partial{u}}\left (-\int_v^uf(w,y)\, dy\right )=-\frac{\partial}{\partial{u}}\left (\int_v^uf(w,y)\, dy\right )=-f(w,u)}$ and $\displaystyle{\frac{\partial{H}}{\partial{v}}(u,v,w)=\frac{\partial}{\partial{v}}\left (\int_u^vf(w,y)\, dy\right )=f(w,v)}$, right? (Wondering) The derivative $\displaystyle{\frac{\partial{H}}{\partial{w}}(u,v,w)=\frac{\partial}{\partial{w}}\left (\int_u^vf(w,y)\, dy\right )=\int_u^v\frac{\partial}{\partial{w}}f(w,y)\, dy=\int_u^vf_w(w,y)\, dy}$ is correct, or not? (Wondering)
So, we get \begin{align*}F'(x)&=\frac{\partial{H}}{\partial{u}}(g(x), h(x), x)\cdot g'(x)+\frac{\partial{H}}{\partial{v}}(g(x), h(x), x)\cdot h'(x)+\frac{\partial{H}}{\partial{w}}(g(x), h(x), x)\\ & = -f(x, g(x))\cdot g'(x)+f(x, h(x))\cdot h'(x)+\int_{g(x)}^{h(x)}f_x(x,h(x))\, dy\end{align*}
right? (Wondering)
Indeed. All correct. (Happy)
All of that can be encapsulated into "Leibniz's rule":
\frac{d}{dx}\int_{\alpha(x)}^{\beta(x)} F(x, t)dt= \frac{d\beta}{dx}F(x, \beta(x))- \frac{d\alpha(x)}{dx}F(x,\alpha(x))+ \int_{\alpha(x)}^{\beta(x)} \frac{\partial F(x,t)}{\partial x} dx
Thank you very much! (Smile)
  • · Replies 16 ·
