Derivative of natural log function questions
10 replies · 2K views
SYoungblood
Hello, I had a few derivative of the natural logarithm functions questions. It seems like it should be fairly straightforward, but I am turning it into a pig’s ear.On my honor, none of these are problems on an assessment per se, however, they are not materially different than anything that I am finding in my calc book and what I would assume to be on a midterm or final:
[/B]
a) ln 3x
b) ln 3x + x
c) ln (3x + 4)
d) ln (x^2)
e) ln x^2
f) x (ln 2x)^4
a) I believe I got this right – 1/3x
b) I think I have this one as well – 1/3x + 1
c) I have (3x + 4)’/(3x + 4) = 3/(3x + 4)
d) Using the chain rule, I believe this is 2x/x^2
e) I believe using the ln x derivative rules, this is 2 (ln x)’ = 2/x
f) This is giving me problems. Using the product rule and chain rule, I think the answer
= 1 * (ln 2x)^4 + x * 4(ln 2x)^3 * 1/2x
= (ln2x)^4 + 4 [(ln 2x)^3]/x, with an x in the numerator and denominator in the final term cancelling each other out.
Thank you for your help --
SY
[/B]
a) ln 3x
b) ln 3x + x
c) ln (3x + 4)
d) ln (x^2)
e) ln x^2
f) x (ln 2x)^4
Maybe, but you didn't write it correctly. I think you mean 1/(3x) but what you wrote is (1/3)x.
Also, you need to use the chain rule.
As above. This should be written as 1/(3x) + 1. You need to use the chain rule, though.
Looks good
This should be simplified. Since ln(x2 = 2ln(x), its derivative is 2/x.
Aren't d and e the same question?
That is, unless you mean (ln(x))2
Did you forget to write the factor of x in the numerator?
I agree that the x factors in the numerator and denominator cancel.
SY
SYoungblood said:
a) ln 3x
b) ln 3x + x
Is that what you meant or do you mean ln(3x+x)? Just curious, could be either way.
Nope. Needs chain rule, even if you meant 1/(3x).
Nope Same problem.
a) I forgot to write it as 1/ (3x) -- it looked better handwritten on paper.
b) Same traffic -- it should say [1/(3x)] + 1
c) Woo-hoo! -- basically a thru c are good to go.
d) I have that written as ln (x^2) -- that is where I had the chain rule as giving a derivative of 2x/(x^2) = 2/x
e) That one should be (ln x)^2 -- 2 ln x, again with an answer of 2/x
f) y = x(ln 2x)^4
Not sure if I missed an x in the first attempt, but here, I still have the product rule and chain rule as:
y' = 1 * (ln 2x)^4 + x * 4(ln 2x) ^3 * 1/(2x)
y' = (ln 2x) ^4 + 4x (ln 2x) ^3 / (2x) -- the 4x in the numerator and 2x in the denominator cancel out, with a numerator of 2 left
y' = (ln 2x)^4 + 2 (ln 2x)^3
Thoughts?
Thanks for all help
SY
f) y = x(ln 2x)^4
Thoughts?
Thanks for all help
SY
Let's just start with the first one. As LCKurtz has already pointed out, the derivative is not 1/(3x). Fix that one first.
f) y = x(ln 2x)^4
Thoughts?
Thanks for all help
SY
f) now looks good.
- but (e) is another matter.
## \left(\ln(x)\right)^2\ne 2\ln(x)##
Use the chain rule. This is much like the ##\ \left(\ln(2x)\right)^4\ ## portion of part (f), but simpler.
SammyS said:
f) now looks good.
y = (ln x)^2
y' = 2 ln x * 1/x
y' = (2 ln x)/x
I think I got it this time.
Also, another above problem --
y = ln 3x
y' = 1/(3x) -- correct or not?
SY
SYoungblood said:
y = (ln x)^2
y' = 2 ln x * 1/x
y' = (2 ln x)/x
y = ln 3x
SY
First one correct, second one not correct. Try the chain rule.
y' = [1/(3x)] * 3 = 3/(3x) = 1/x
Thanks to all for the help. Derivatives of ln x and I had a long day today.
