Derivative of y = cos(a^3 + x^3)
  • Thread starter Thread starter illjazz
    Derivative
The derivative of the function y = cos(a^3 + x^3) is calculated using the Chain Rule and Power Rule. The correct derivative is y' = -3x^2 sin(a^3 + x^3), as the term involving a^3 vanishes since it is treated as a constant. This clarification resolves confusion regarding the differentiation of constants in the context of variable derivatives. The discussion also touches on the use of Leibniz notation and its implications in derivative calculations.
  • Understanding of the Chain Rule in calculus
  • Familiarity with the Power Rule for differentiation
  • Knowledge of trigonometric functions and their derivatives
  • Basic understanding of constants in differentiation
  • Study the application of the Chain Rule in more complex functions
  • Explore the implications of treating constants in differentiation
  • Learn about the differences between Leibniz notation and Lagrange notation
  • Practice finding derivatives of trigonometric functions with polynomial arguments
Students studying calculus, particularly those focusing on differentiation techniques, as well as educators looking for clarification on common misconceptions in derivative calculations.
illjazz
Find the derivative of the function y = cos(a^3 + x^3).
- Chain rule
- Power rule
This is driving me insane.. so here's what I have.
y = cos(a^3 + x^3)
y' = -sin(a^3 + x^3) * d/dx (a^3 + x^3)
y' = -sin(a^3 + x^3) * (3a^2 + 3x^2
y' = -(3a^2)(sin(a^3 + x^3)) - (3x^2)(sin(a^3 + x^3))
I would like to think that that's where this ends.. but my book claims the result is
y' = -(3x^2)(sin(a^3 + x^3))
How? Where the heck does that entire -(3a^2)(sin(a^3 + x^3)) term go!?
Hence, dy/dx not dy/dx + dy/da!
Ah! Ok that makes sense on an intuitive level.. can you expand that a bit though? Does a simply turn into 0 and thus kill that whole term containing a as a factor?
Thanks!
Edit:
By the way.. I stay far, far away from the dy/dx notation wherever possible. I just don't quite understand it.. for instance, I cringe when I see this in my book:
\frac{dy}{dx}=\frac{\frac{dy}{dt}}{\frac{dx}{dt}}
if
\frac{dx}{dt}\neq0
for example.. I much prefer something like
F'(x) = f'(g(x)) * g'(x).
Granted, the two examples are not equivalent for the purposes of comparison.. but it gets the point across. I suppose that explains why Leibnitz' notation throws me off :/
y'=\frac{dy}{dx}
Means to take the derivative of y with respects to x. Basically, only take the derivative of terms that include x.
y=ax+a
You could easily mistake this as product rule, but it's not! (but you could if you wanted to) Anything that does not have an x variable associated with it, is a constant.
\frac{dy}{dx}=a
or product rule (pointless)
\frac{dy}{dx}=a\frac{dy}{dx}x+x\frac{dy}{dx}a+\frac{dy}{dx}a=a\cdot1+x\cdot0+0=a
y'=\frac{dy}{dt}
Simply means to take the derivative of y with respects to t or time. You can use any variable you want.
- Chain rule
- Power rule
y = cos(a^3 + x^3)
y' = -sin(a^3 + x^3) * (3a^2 + 3x^2)
No. d/dx(a^3+ x^3)= 3x^2. a^3 is a constant
Sweet, that definitely helps :)
While we're here.. is it against the rules or anything to ask a second question about a new problem in the same thread? Seems like a bit of a waste to start a new thread just for this next one..
Here goes. If this is bad and frowned upon, let me know! (I understand, obviously, that as a general rule you don't want to do this.. but this one's so short I figure "what the hell"):
y=xe^{-x^2}
I know the solution already, of course, but I'd appreciate a step by step "walkthrough".
I got as far as this:
<br /> y=xe^{-x^2}<br />
<br /> y&#039;=x\frac{d}{dx}e^{-x^2}+e^{-x^2}\frac{d}{dx}x<br />
<br /> =xe^{-x^2}+e^{-x^2}<br />
Also, can someone tell me why I can't seem to make a new line when writing tex? "\\" is supposed to do it.. but does not :/
Oh btw.. the reason for the last step above was the assumption that the following is true:
<br /> \frac{d}{dx}e^x=e^x
\frac{d}{dx}e^x=e^x is true because the derivative of x is 1 (by power rule = derivative of x is 1 * x^(1-1)). If, in place of x, there was a function based on x (for example, 2x + 1), you would have e^(2x+1) multiplied by the derivative of the function, resulting in 2e^(2x+1) by the Chain Rule.
Having said that, there is a flaw in your walkthrough. The derivative of e^(-x^2) would be, by the combination of the Chain Rule and the Power Rule, would be -2xe^(-x^2). Hence, your final answer should come out to -2x^{2}e^{-x^2}+e^{-x^2}.
It's not "against the rules", but many people will not look at a thread when they know the initial question has been answered- so you may be ruducing the number of people who see your new question.
y=xe^{-x^2}
Yes, that last line is true. But it is NOT true that
{d e^{x^2}}{dx}= e^{-x^2}
You forgot the chain rule: multiply by the derivative of -x2.
Hello there:
Here is my solution, which matches your textbook's.
y = \cos(a^3 + x^3)
Let: u = a^3 + x^3
The Chain Rule: h&#039;(x) = f&#039;(g(x)) \times g&#039;(x)
Breaking the original equation down:
f(x) = \cos u, f&#039;(x) = -\sin u
g(x) = u = a^3 + x^3, g&#039;(x) = 3x^2 (From the Product Rule)
Note: 3a^2 is actually a constant due to the term a. Recall that the derivative of any constant is 0.)
Compiling each function:
h&#039;(x) = f&#039;(u) x 3x^2
h&#039;(x) = -\sin(a^3 + x^3)(3x^2)
h&#039;(x) = -3x^2 \sin(a^3 + x^3)
Hope this helps.
Thanks everyone. Your posts helped a lot! What threw me off, I believe, is that e's exponent had itself an exponent.. but what I need to remember specifically is the bold part quoted above!
Thanks again :)
I know this is probably really late, but I'd like to point out to rocomath his/her mistake in using the Leibniz notation: you should have used \frac{d}{dx}, not \frac{dy}{dx}. The first one means "take the derivative of" and the second means "the derivative of y with respect to x is".
Just being nitpicky. =]
And that actually helped me understand Leibniz a bit better! Thanks :)
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 24 ·
