Derivatives of functions with matrices
8 replies · 8K views
Leo321
I try to understand how to calculate derivatives of functions, which contain matrices.
For a start I am looking at derivatives by a single variable.
I have x=f(t) and I want to calculate [tex]\frac{dx}{dt}[/tex]. The caveat is that f contains matrices, that depend on t. Can I use the ordinary chain rule and product rule, and if not, then what can I use?
What for example would be [tex]\frac{d}{dt}Tr(M^kA)[/tex]? Assume M is a function of t and A is constant. Would it be [tex]kTr(M^{k-1}\frac{dM}{dt}A)[/tex], like it would have been for a scalar?
Take as an example k=2. Then
[tex]\frac{d}{dt}M(t)M(t)=\dot{M}M+M\dot{M}[/tex]
If [tex]M[/tex] and [tex]\dot{M}[/tex] do not commute - that is all you can have. If your A does not commute with M and its derivative, then trace will not help.
So, yes, the chain rule applies, but noncommutativity needs to be taken into account, so differentiating M^k you will have k terms (with [tex]\dot{M}[/tex] at k different plces) and not just one.
Fredrik said:
Just write
[tex]\operatorname{Tr}(A(t)B(t))=\sum_{i=1}^n a_i(t) b_i(t)[/tex]
and use the usual rules on the right-hand side.
What are [tex]a_i[/tex] and [tex]b_i[/tex] on the RHS?
Your formula gives:
[tex]d/dt (AB)=d/dt(A)B+Ad/dt(B)[/tex] - the Leibniz rule, and only under the trace. The rule is valid also without the trace.
There are two things I think Leo needs to understand here:
1. The derivative of a matrix-valued function defined on a subset of the real numbers is just the matrix of derivatives of the component functions.
2. Matrix multiplication and many other operations (like the trace) are defined using only addition and multiplication of real (or complex) numbers.
These two facts reduce problems of the sort described in #1 to problems that require no knowledge of matrices.
Not really. Because we have the following nice formulas like:
[tex]\frac{d}{dt}\exp (At)=A\exp(At)[/tex]
or this:
[tex]\frac{d}{dt}( A(t)^{-1})=-A(t)^{-1}(\frac{d}{dt}A(t))A(t)^{-1}[/tex]
I do not know how you would derive such a formula without knowing about operations with matrices. It would be rather tedious...
Thanks!
