Deriving a function from within an integral with a known solution
6 replies · 2K views · last reply
Phylosopher
Hello,I am not sure if these types of problems are Intermediate or advanced. I am not sure too whether they have a certain name or not.
I have a function inside a definite integral. The solution of this definite integral is known. What is the function that satisfy the known solution.
In mathematical terms: ## \int_{-∞}^{∞} f(x) g(x) \, dx = h##
f(x) is the unknown function while g(x) is a known function and h is the known solution of the integral. The actual problem that I have is way harder than demonstrated, but the basic idea is the same. How can I find f(x) that satisfy the solution h.
(If its indefinite integral of course) If h ∝ x. I would have an indefinite integral and then differentiate both sides of the equation and finally have ##f(x)=\frac {1} {g(x)}\frac {dh(x)} {dx} ##. I think this is the right approach if h∝x with indefinite integrals. But its not, its independent of x.
I don't believe it can be done with a definite integral in which case ##h## is just a number. I don't have a general proof, just a counterexample that ##f(x)## is not unique. Suppose it is given that ##g(x)=\frac{1}{1+x^2}## and ##h=\pi/6.##
Then ##f(x) = \frac{1}{x^2+4}## and ##f(x) = \frac{4}{9(x^2+1)^2}## work equally well to give ##\int_{-∞}^{∞} f(x) \frac{1}{1+x^2} \, dx = \pi/6.##
I found a way to find f(x).
I basically took H(∞)-H(-∞)=h and then assumed H(-∞)=0, and so H(∞)=h which means H(x) must be a function with lim→∞ =h while lim→-∞ =0.
One can use any function that satisfies the two conditions and define H(x)=z(x)*h. z(x) satisfies the conditions lim→∞ =h while lim→-∞ =0. After that, we can reduce the definite integral to indefinite one since we know what is H(x) and use the method wrote in the earlier post:
##f(x)=\frac {1} {g(x)} h \frac {dz(x)} {dx} ##
But as you said, the solution for f(x) is not unique. Anyway, for my problem I actually don't need a unique solution. In the contrary, I actually want this discrepancy.
Thanks for your reply sir.
This is a classic Hilbert space problem. Essentially your problem is: Given [itex](f, g)=h[/itex] find f. First, observe that f is not uniquely defined. Any q such that [itex](q, g)=0[/itex] can be added to any solution and the resulting f will still be a solution.
Now take any orthonormal basis in your function space and express g in that basis: [itex]g=\sum_{n=0}^{\infty}g_{n}e_{n}[/itex]. Assume that a solution exists, then it can be expressed in the same basis as [itex]f=\sum_{n=0}^{\infty}f_{n}e_{n}[/itex]. This means that [itex](f,g)=\sum_{n=0}^{\infty}f_{n}\cdot g_{n}[/itex]. This transforms your problem into [itex]\sum_{n=0}^{\infty}f_{n}\cdot g_{n} = h[/itex] which obviously is underdetermined.
Now take any orthonormal basis in your function space and express g in that basis: [itex]g=\sum_{n=0}^{\infty}g_{n}e_{n}[/itex]. Assume that a solution exists, then it can be expressed in the same basis as [itex]g=\sum_{n=0}^{\infty}f_{n}e_{n}[/itex]. This means that [itex](f,g)=\sum_{n=0}^{\infty}f_{n}\cdot g_{n}[/itex]. This transforms your problem into [itex]\sum_{n=0}^{\infty}f_{n}\cdot g_{n} = h[/itex] which obviously is underdetermined.
That is some advanced mathematics for me. I will read more on the subject of Hilbert spaces.
Thank you sir.
Since neither ∞ nor -∞ are considered actual numbers, it's not legitimate to evaluate H at either of these or otherwise do arithmetic with either one. If H is some function of x, you can however take the limit: ##\lim_{x \to \infty}H(x)##.
They are called integral equations. If you have learned linear algebra then you have the background needed to learn how to solve (exactly or approximately) some of them.
