Deriving expressions for Fourier Transforms of Partial Derivatives
The discussion focuses on deriving expressions for the Fourier Transforms of the partial derivatives ∂u/∂t and ∂u/∂x using the formal limit definition of the derivative. The Fourier Transform of a function u(x,t) is defined, and the attempt to derive the transform for ∂u/∂t shows that the limit can be pulled outside the integral, leading to a straightforward expression. However, confusion arises when addressing the Fourier Transform of ∂u/∂x, where the participant is unsure how to handle the limit and the differential notation. Suggestions are made to avoid using "dx" inappropriately, and the final result for ∂u/∂x is approached by manipulating the integral and applying limits correctly.
N00813
Using the formal limit definition of the derivative, derive expressions for the Fourier Transforms with respect to x of the partial derivatives \frac{\partial u}{\partial t} and \frac {\partial u}{\partial x}.
The Fourier Transform of a function u(x,t) is:
<br /> \tilde{u}(k,t) = \int_{-\infty}^{\infty} u(x,t) e^{-ikx} dx<br />
I attempted to write the FT of the derivative with respect to time as \lim_{dt \to 0} \frac{u(x,t+dt) - u(x,t)}{dt} and then Fourier Transform it. Pulling the limit outside the integral, I got FT of (\frac{\partial u}{\partial t}) = \tilde{\frac {\partial u}{\partial t}}(k,t).Now, with the partial derivative of x, I'm not so sure. The partial derivative wrt x is \lim_{dx \to 0} \frac{u(x + dx,t) - u(x,t)}{dx}. When placed in the Fourier transform, I don't know what I can do. I don't think the dx at the end of the integral cancels out the dx in the definition of the derivative.
You should avoid using "dx" and so forth as anything other than part of a derivative or integral (or as a differential form). Otherwise you run into this sort of confusion. When taking limits, use either \delta x or another letter.
You want to calculate
<br /> \int_{-\infty}^\infty \lim_{h \to 0} \frac{u(x+h, t) - u(x,t)}h e^{-ikx}\,dx<br /> = \lim_{h \to 0} \frac1h \left( \int_{-\infty}^\infty u(x + h, t)e^{-ikx}\,dx - \int_{-\infty}^\infty u(x, t)e^{-ikx}\,dx \right)<br />
Likes 1 person
Thanks, I must have derped out last night.
I'm thinking about turning the 2nd term into \lim_{h \to \infty} \frac{1}{h} \tilde{u}(k,t) and substituting the y = x + h into the first term, to give a final result of:
<br /> \lim_{h \to 0} \frac{1}{h} ((e^{ik(0+h)}-e^{ik0}) \tilde{u}) = ike^{0} \tilde{u}<br />
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
