Deriving tensor transformation laws
3 replies · 3K views
Daniel_C
TL;DR
I'm attempting to understand how the definition of a tensor in terms of how it transforms arises from demanding invariance of the tensor when we define it as a multilinear map
Hi, I'm worried I've got a grave misunderstanding. Also, throughout this post, a prime mark (') will indicate the transformed versions of my tensor, coordinates, etc.
I'm going to define a tensor.
$$T^\mu_\nu \partial_\mu \otimes dx^\nu$$
Now I'd like to investigate how the tensor transforms under an arbitrary coordinate transformation where I require that the tensor is invariant under the coordinate transformation. In order to understand how partial-mu transforms, I'm going to apply the chain rule for partial derivatives.
$$\begin{equation} \partial'_\alpha = \frac{\partial}{\partial x'^\alpha} = \frac{\partial x^\mu}{\partial x'^\alpha}\partial_\mu \end{equation}$$
Similarly, I can write down how the basis one-forms transform.
$$\begin{equation} dx'^\alpha = \frac{\partial x'^\alpha}{\partial x^\mu} dx^\mu \end{equation}$$
Therefore, the basis of my tensor transforms like this:
$$\begin{equation} T'^\alpha_\beta \partial'_\alpha \otimes dx'^\beta = T^\mu_\nu \frac{\partial x^\mu}{\partial x'^\alpha} \partial_\mu \otimes \frac{\partial x'^\alpha}{\partial x^\mu} dx^\nu \end{equation}$$
Which mirrors my more familiar definition of a tensor in terms of how it's components transform:
$$\begin{equation} T'^\alpha_\beta = \frac{\partial x'^\alpha}{\partial x^\mu}\frac{\partial x^\nu}{\partial x'^\beta} T^\mu_\nu \end{equation}$$
Is it correct to write down the transformation of the tensor in the way I did in equation (3)? Is this equivalent to equation (4)?
Please help me if I've had a misunderstanding. Thank you very much for any help.
Daniel_C said:
Summary: I'm attempting to understand how the definition of a tensor in terms of how it transforms arises from demanding invariance of the tensor when we define it as a multilinear map
Yes. Yes (the base tensors ##\partial_\mu \otimes dx^\nu## form a complete and linearly independent basis).
Edit: Also note that the tensor product is linear and that the partial derivatives are just numbers that you can move out of it.
Thanks so much for the quick reply!
$$T'^\alpha_\beta \partial'_\alpha \otimes dx'^\beta = T^\mu_\nu \frac{\partial x^\mu}{\partial x'^\alpha} \partial_\mu \otimes \frac{\partial x'^\alpha}{\partial x^\mu} dx^\nu$$...
Note that the RHS of your equation 3 is not a valid expression as you have four ##\mu## indices. You need to change either the inner two ##\mu##’s or the outer two for this to make sense. But even then, if you’re wanting to use equations 1 and 2 and the fact that a tensor remains the same despite a change in basis in order to derive eq. 4, then this might be a more intuitive approach:
\begin{equation*}
\begin{split}
\mathbf T = T^{\bar \alpha}_{\bar \beta} ~ \partial_{\bar \alpha} \otimes dx^{\bar \beta} & = T^{\bar \alpha}_{\bar \beta} (\frac{\partial x^\mu}{\partial \bar x^{\bar \alpha}} \partial_\mu ) \otimes (\frac{\partial \bar x^{\bar \beta}}{\partial x^\nu} dx^\nu) \\
& = (T^{\bar \alpha}_{\bar \beta} \frac{\partial x^\mu}{\partial \bar x^{\bar \alpha}} \frac{\partial \bar x^{\bar \beta}}{\partial x^\nu}) \partial_\mu \otimes dx^\nu
\end{split} \tag{5}
\end{equation*}
$$And because ##\mathbf T## is unchanged by a change in basis, we can say that
$$T^{\bar \alpha}_{\bar \beta} ~ \partial_{\bar \alpha} \otimes dx^{\bar \beta} = T^\mu_\nu ~ \partial_\mu \otimes dx^\nu$$
And therefore
$$T^\mu_\nu = T^{\bar \alpha}_{\bar \beta} \frac{\partial x^\mu}{\partial \bar x^{\bar \alpha}} \frac{\partial \bar x^{\bar \beta}}{\partial x^\nu}$$
We can rearrange like we did in the 2nd line of eq. 5 precisely because of the reason @Orodruin gave in the edit of his post.
