Deriving the spherical harmonics addition theorem
12 replies · 3K views · last reply
amjad-sh
Hello.
I was recently reading Barton's book.
I reached the part where he proved that in spherical polar coordinates
##δ(\vec r - \vec r')=1/r^2δ(r-r')δ(cosθ-cosθ')δ(φ-φ')##
##=1/r^2δ(r-r')δ(\Omega -\Omega')##
Then he said that the most fruitful presentation of ##δ(\Omega-\Omega')## stems from the closure property of the spherical harmonics ##Y_{lm}(\Omega)## which constitute a complete orthonormal set over the surface of the unit sphere.
Then he said that the spherical harmonics satisfies the remarkable addition theorem:
##\sum_{m=-l}^{m=l}Y_{lm}^*(\Omega')Y_{lm}(\Omega)=(2l+1/4π) P_l(\vec r \cdot \vec r')##
My problem is that I didn't get from where he obtained this relation.
Besides he said that the angle##\chi## between ##\vec r## and ##\vec r'## is
##cos\chi=\vec r \cdot \vec r'={cosθcosθ'+sinθsinθ'cos(Φ-Φ')}##
Where the vector where ##\vec r## and ##\vec r'## are two vectors in spherical coordinates.
If somebody can help me obtaining this relation too.
Thanks.
At least this relation is easy to derive from the representation of the unit vector r in terms of the anlges ##\theta## and ##\phi##,
##r=(\cos \phi \sin \theta, \sin \phi \sin \theta, \cos \theta)^T## and the addition theorems for the cosine and sine of ##\phi##.
amjad-sh said:
∑m=lm=−lY∗lm(Ω′)Ylm(Ω)=(2l+1/4π)Pl(⃗r⋅⃗r′)∑m=−lm=lYlm∗(Ω′)Ylm(Ω)=(2l+1/4π)Pl(r→⋅r→′)\sum_{m=-l}^{m=l}Y_{lm}^*(\Omega')Y_{lm}(\Omega)=(2l+1/4π) P_l(\vec r \cdot \vec r')
I think this is easierst to prove noting that the lhs is invariant under rotations. Hence we may rotate ## r \to (0,0,1)^T## and ##r' \to (\sin(\theta), 0, \cos(\theta))^T##, with ##r\cdot r' =\cos(\theta)##. Can you fill in the remaining steps?
Not exactly.
I still didn't get the figure yet.
##Y_{lm}(θ,φ)=(-1)^m\sqrt{(2l+1/4π)(l-m)!/(l+m)!}P_l^m(cosθ)e^{(imφ)}## is the joint eigen function of ##\hat L^2 and \hat L_z##
should I use this to obtain it?
amjad-sh said:
Not exactly.
Yes. What is the value of ##P_l^m(1)##?
DrDu said:
Yes. What is the value of Pml(1)Plm(1)P_l^m(1)?
its value is zero since ##P_l^m(x)=(1-x^2)^{|m|/2}\frac {d^{|m|}}{dx^{|m|}}P_l(x)##
where ##p_l(x)=1/(2^l l! )\frac {d^l}{dx^l}(x^2-1)^l##
Thats not always true.
when it is not?
DrDu said:
Start to check for the lowest values of l an m.
I found that they are equal to 1 only when m=0 and by this ##P_l^m(1)=1## If I substitute in ##\sum_{m=-l}^{m=l}Y_l^m(\Omega')^*Y_l^m(\Omega)## what I will get is ##(2l+1)/4π P_l^2(1)## which is equal to ##2l+1/4π##.
you said that the l's are invariant under rotation.I think because ## \hat L^2## commutes with ##\hat H##, ##[\hat H,\hat L^2]=0##
you mean choosing any ##\vec r## ,##\vec r'## suffices in proving the whole relation?
but if you chose other ##\vec r## and ##\vec r'## the relation will end up with ##P_l^2(\vec r \cdot \vec r')## and not ##P_l(\vec r \cdot \vec r')## isn't this true?
and why it is ##P_l(\vec r \cdot \vec r')## and not ##P_l(cosθ)## as the solution of the legendre differential equation is ##\Theta_{lm}(θ)=c_{lm}P_l^m(cosθ)##?
... and 0 if m not equal 0.
No, be carefull! If ##\cos \theta =1##, ##\cos \theta' <1## in general.
DrDu said:
No, be carefull! If cosθ=1cos⁡θ=1\cos \theta =1, cosθ′<1cos⁡θ′<1\cos \theta'
OK. So the relation will end up like this:##(2l+1)/4πP_l^0(cosθ')##.
How can I reach ##P_l(\vec r \cdot \vec r')## now?
Note that the Ylm span an irreducible and unitary representation of the rotation group, i.e. ## Y_l^m(R^{-1} r)=\sum_m U_{m m'} Y_l^m'(r)##, where R is a 3x3 rotation matrix and U a (2l+1)x(2l+1) unitary matrix. You can use this to show that ##\sum_{m=-l}^{l} Y^{m*}_l(r') Y^m_l(r)=\sum_{m=-l}^{l} Y^{m*}_l(e') Y^m_l(e_z)##, where ##e_z= (0,0,1)^T## and ##e'=(\sin(\arccos(r\cdot r')), 0, r\cdot r')^T##
