How to Design an Automotive Bumper to Absorb Impact?
  • Thread starter Thread starter James22
    Automotive Design
This discussion focuses on designing an automotive bumper capable of absorbing impact energy effectively. The user calculated the kinetic energy of a 3702 lbs car moving at 7.33 ft/s, resulting in 3091.38 ft-lb. They proposed using a 6" crumple zone and four springs to absorb the impact, with each spring needing to handle one-fourth of the total kinetic energy. The user also explored using foam characteristics to design the bumper, seeking to calculate deceleration based on the force derived from the kinetic energy spread over the bumper's surface area of 393 in².
  • Understanding of kinetic energy calculations (E=1/2 mv²)
  • Knowledge of spring mechanics (U=0.5*k*s²)
  • Familiarity with foam material properties (PSI vs deflection)
  • Basic principles of force and acceleration (F=ma)
  • Research the properties of different foam materials for impact absorption
  • Learn about advanced spring design and selection criteria
  • Investigate methods for calculating deceleration in automotive applications
  • Explore automotive safety standards related to bumper design
Automotive engineers, mechanical design students, and professionals involved in vehicle safety and impact analysis will benefit from this discussion.
James22
I have attached the assignment below. The weight of the car will be 3702lbs
I am not sure if I am on the right track, but so far I have calculated the kinetic energy as;
E=1/2 mv^2
0.5 x (3702/32.2) x 7.33ft/s^2 = 3091.38 ft-lb
I have chosen to use a 6" crumple zone and 4 springs to absorb the impact.
This is where I run into trouble trying to get my head around the concept.
I know for the spring
U=0.5*k*s^2
where;
k = spring co-efficient
s = spring displacement
Since I am trying to stop the car in 6" do I have to treat the kinetic energy as double? Then divide it over the 4 springs that I will be using to stop the car?
Thanks,
Kyle
After 6" your 4 springs combined needs to absorb all the kinetic energy of the moving car.
In other words, each spring needs to absorb 1/4 of the kinetic energy.
Energy before = energy after
E = U_1 + U_2 + U_3 + U_4 , and solve for k
Thank you SirAskAlot, I completed the calculations for the spring bumper using your assistance. Now I have to design a bumper using some type of foam. My professor provided me with a few graphs of the characteristics of foam (PSI vs deflection). I have decided to use a 65.5" wide by 6" tall bumper to represent the average midsized car. That works out to have a surface area of 393in^2
What I am struggling with is the fact that I will need to calculate deceleration, so I will need to know the force (I was planning on using a=F/m).
My initial thought was to take the kinetic energy (3091.3 ft-lb) and convert it to in-lb (37092 in-lb)
Then I went;
37092 in-lb / 393 in^2 = 94.38 lb/in
Is it possible to spread the kinetic energy over the bumpers surface area like this? I still need the stopping force to calculate deceleration though.
Thank you in advance.
  • · Replies 27 ·
