Design Tripod to Support 20kg Mass at 2m: A Student Guide
  • Thread starter Thread starter Tim Allen
    Design
The discussion revolves around the design of a tripod intended to support a 20kg mass at a height of 2m, specifically for use with a mobile laser scanner. Participants explore various design considerations, including structural integrity, mobility features, and the mechanics of load distribution.
  • Homework-related
  • One participant outlines the need to calculate the bending moment and stress on the tripod legs due to the 20kg mass, expressing uncertainty about the next steps.
  • Another participant suggests that the design should first consider the tripod as a mechanism, asking for a sketch to better understand the proposed design.
  • Participants discuss the need for mobility features like casters or wheels, along with a method to immobilize the tripod during scanning.
  • Concerns are raised about the vibration tolerance of the laser scanner, questioning whether it can withstand vibrations while the tripod is moved.
  • Some participants propose using dampening features and soft tires to mitigate vibrations during movement.
  • A later reply indicates a change in design to include bracing at the bottom of the legs and requests assistance with force diagrams and stress analysis.
  • Another participant emphasizes the importance of understanding how the weight load from the scanner distributes between the column and the legs.
Participants express various viewpoints on design features and calculations, with no consensus reached on specific methods or solutions. The discussion remains unresolved regarding the optimal design and calculations needed for the tripod.
Participants highlight the need for sketches and technical drawings to clarify design proposals. There are also mentions of assumptions regarding the tripod's structural connections and load distribution that remain unverified.
Tim Allen
I am designing a tripod which is for supporting a mass of 20kg at a height of 2m from the ground. The legs are cylindrical and hollow, dimensions are not set in stone, and would be made from an aluminium alloy. I do not want the legs to be bound at the bottom, they should be free to move so the tripod can be adjusted in height.
Could someone please advise how I begin? I know that my 20kg mass will exert a downward force of 196.2N due to gravity, but I don't know what the next step should be. I suspect I need to calculate the bending moment but I am not certain how to go about this. Furthermore, once I know the bending moment due to the force, how do I then calculate the stress which is acting on the legs? I have come across Euler's Formula for the max axial load for a long, slender column and I think I need to use this at some stage but not sure when exactly. Excuse my ignorance, I'm only a student!
If the legs are to be moveable then you need to design this tripod as a mechanism first . What is the practical construction going to be ?
Post a sketch of what you think is a plausible design and we'll have a look .
The actual strength calculations are relatively simple and we can deal with these later .
What constraints do you have for how the mass attaches to the tripod? Is there a formal problem statement, or some other guidelines? What does the mass look like?
What are your initial thoughts for how you will attach the mass to the tripod. Depending on the constraints that you have been given, there may be an innovative way you can attach the mass to the tripod to maximize stability and strength of the overall structure... :smile:
OK guys, thanks for the feedback.
To give you a bit more info, essentially what this is is a method for making a laser scanner mobile, so I'm wanting to design a tripod system that is mobile. The laser scanner attaches to the top of the tripod using a standard Tribrach attachment. The mass itself is a laser scanner, it's essentially a rectangular box that weighs approximately 9kg, but I wanted to design the tripod to support more weight than that.
I want to design something that can make the tripod mobile, so it needs to have casters or wheels but also it must have a method of immobolising so that it can be held in place whilst a scan takes place. My thoughts are either to use a simple braking caster system or a pin that lifts the wheels from the ground temporarily.
Sketch attached - it is by no means perfect, it gives a rough idea of what I'm thinking.
Ah, then my idea won't work. I was going to suggest mounting the mass underneath the apex of the tripod, to add stability and strength. That won't work for a laser scanner.
How do you plan to level the scanner?
The scanner can be levelled on the Tribrach attachment, it allows a 3 point adjustment.
Any advice on how I can calc the bending moments and stresses?
I'll leave the help on the calculations to others like @Nidum but I wanted to ask about the vibration tolerance of the laser scanner you are planning on using. Were you planning on rolling the whole assembly around on casters with the laser scanner still in place? That might be pretty harsh on the scanner unit. Or are you planning on detaching the scanner any time that you are going to start wheeling the tripod around.
If you want to wheel the whole assembly around, you should check the vibration and shock specifications of the scanner. It's probably not designed to take a lot of vibration without losing calibration and accuracy...
Thanks berkeman for your advice.
Yes, the theory is that the whole unit will be wheeled around to speed up the process of laser scanning a vast area such as a car park or onshore gas installation. The company that I work for specialise in laser scanning so I will double check with them the limits on vibration for throwing out the calibration. I was certainly going to take into account that vibration might affect the actual scanning process if vibrations are present in the local environment due to plant or other machinery nearby.
Perhaps involving some sort of dampening might be an added advantage in the design. Thanks
Yes, maybe some dampening, and probably best to use soft tires (not hard casters) with a reasonable radius.
Can anyone help please? @Nidum ? I have changed the design slightly from what I posted originally. The legs are now braced at the bottom. I need some assistance in completing force diagrams/stress analysis... HELP
Please post a drawing of the structure that you now propose using . Preferably a proper technical drawing done using CAD but a good hand sketch will do pro tem .
@Nidum for some reason I cannot see your reply, it says 'error' when I click on the attachment..
(1) Assume that the column , legs and cross struts are all pin fixed to each other .
(2) The column is not supported at the lower end by contact with floor or by rigid connection to the cross struts .
So how does the weight load from the instrumentation unit distribute between the column and the three legs ?
I think the weight load from the instrument and self weight load of the columns is transmitted through the 'locking mechanism' (a collar which is tightened) when the tripod is extended at height, and from here spreads down the legs and column by means of a head piece which supports the connections for the top of the legs. Is this what you mean or have I misunderstood your question?
Essentially correct . The instrument and column weight loads sum at the connecting collar and are supported by the legs only .
So what does the idealised structure and loads diagram look like for anyone leg and cross strut ?
Do you want some help to draw the diagram ?
Yeah, I'm not certain where to start. Can it be based on the drawing that you referenced in your reply above? That's what I had in mind...
ok. Get back to you asap .
10K
  • · Replies 16 ·
