Designing a helical coil heat exchanger after energy balance
5 replies · 3K views
Davian Francis
really need help in designing a helical coil HE. i know i must first do an energy balance to find heat rate.but what next?to find the area needed and the number of turns etc
Helical flow heat exchangers with tubes are true counter-current exchangers and can be calculated the same as a shell and tube exchanger with one shell pass and one tube pass with the shell-side flow parallel with the tubes. Now, if you mean a spiral exchanger like this:
http://www.tranter.com/Pages/products/spiral/description-benefits.aspx
it's usually easiest to contact the vendor.
Hey thanks for replying. But i was talking about a coil with one inlet one outlet..it will be placed on ice in an ice room, so exit water can be cold.
Do you mean in an ice and water bath (good heat transfer, easy to calculate) or just buried in ice with no water (not so much)?
The coil will just be on ice basically. Room temperature water flows through the coil. So basically a need to determine the amount a turns and so forth to get the water cold.
