sophiecentaur
Homework Helper
- 30,522
- 7,515
Hi
No I didn't read it thoroughly after I came to your 'little gaff' haha. You're not the first to fail to make a reality check. Me too, frequently.
Can you take me through this jet equation? Even there, you end up with a velocity of 300m/s. Is that realistic? Wouldn't a real system with those speeds involved make a huge amount of noise? 150holes! But, if the volume of air in equals the volume of air out, it should end up moving somewhat faster through the holes.
I think that vsquared equation must be too simplified for finding the air flow. It assumes laminar flow and also that pressure is the same all over the bearing surface. This won't be true. There will be more pressure away from the edge (hence, less pressure where you are applying that volume flow calculation). The air in the centre will stay there because its pressure is only a bit higher than the air next to it. (That earlier practical comment of someones, about needing no holes up there confirms what I say. There will be a steep gradient of pressure, I think, between holes and edge. As a reality check, we wouldn't dream of putting the holes right near the edge, would we? So the pressure must be different all over the underside.
I have no idea what the right solution is but I can't even believe an exit speed of 20m/s is right, now I think of it. That's 72km/hr! It would blow your hat off - and, as for the air coming out of the holes at 300m/s, that would drill holes in your skin I think.
This is turning out to be quite hard ain't it?
btw, If you are shifting 0.012m3 at 3.42kPa, doesn't that represent over 4kW? Sorry but I think that's right.
