pioneerboy
- Messages
- 30
- Reaction score
- 1
Hi there,
I am thinking about an electromagnetic levitation project. Imagine a tube of about 13cm diameter with a flat rotation-symmetrical object of maybe 4cm diameter at one of its ends. The object should be oriented always perpendicular to the vertical tube...difficult to explain as I don't have the proper words for it...just imagine a cylinder hat without a full cover on its top. Now if we turn this cylinder in any arbitrary direction, I want that the flat object still stays in the middle of the tube and also perpendicular as before. Of course, the object would oscilate a bit until it reaches its ideal position due to air friction. Also, the movement of the cylinder should only be a few degrees per second. I thought about building some kind of control system that recognizes the tube orientation and increases/decreases the current running through the coils that go around the tube circumference to adjust for changing gravitational situations. How difficult do you expect this to be to build?
Thanks,
Lucius
Thanks,
Lucius
