Detailed electrochemistry question
  • Thread starter Thread starter kmav83
    Electrochemistry
The discussion revolves around a PhD student's confusion regarding the electrochemical behavior of a system involving a platinum electrode, electrolyte, and silicon components under low bias conditions. The student notes that typical oxidation reactions at the platinum electrode cannot occur due to insufficient applied potential, and questions whether electrolysis of water could be a factor, which is ruled out based on E-pH diagrams. Despite the expectation that no current should flow due to the lack of redox reactions, the student observes continuous low-level current at voltages as low as 0.1 V, raising questions about its source. The possibility of side reactions or impurities in the platinum, silicon, and SiO2 is suggested as a potential explanation for the unexpected current. The discussion highlights the complexities of electrochemical systems and the need for further investigation into the reactions occurring at the electrode interface.
kmav83
I am a PhD student and I am trying to decipher what is going on in my system, which consists of a platinum electrode, an electrolyte (varying pH, buffer solution with KCl salt and TRIS buffer), thin SiO2 and Si when low bias is applied to the Pt electrode (0 to 0.5 V) with respect to the Si. I'm sure a double layer will form at the electrolyte-SiO2 interface...and since charge cannot pass between the Si and the SiO2, reactions that contribute to ion current in the electrolyte will only be occurring at the Pt electrode. But I am quite confused because as you can see, this is not a typical electrochemical cell and it becomes hard to imagine operation of such a system.
First, at the Pt electrode, an oxidation reaction involving dissolution of Pt cannot occur because the standard potential of Pt oxidation is -1.18V and therefore the reaction is non-spontaneous. And the applied bias is less than +1.18V, so this reaction cannot even be driven by applied bias. So, the only other reaction I can see happening is 2 H+(aq) + 2e− → H2(g), for which the standard potential is 0V? OR 2H2O(l) + 2e- → H2(g) + OH-(aq)...but the standard potential for this is -0.83V and the applied potential is in the opposite direction...so this reaction becomes impossible. Are there any other reactions that can occur? XXXX This is wrong...See EDIT! XXXX
So, I guess my first question is, if there are no ions in solution that can partake in a redox reaction involving the metal of the electrode and if applied bias is not sufficient to drive that reaction (dissolution of Pt in my case), then the only other possibility is electrolysis of water? Also, which electrolysis half reaction should occur...only hydrogen gas evolution (since applied bias is low and positive)?EDIT: Actually according to E-pH diagrams, water is stable (at neutral pH) between 0 and 1 V applied bias. So...there can be no electrolysis reaction at the metal electrode. So, this makes things even more confusing. At low positive voltages, even electrolysis cannot occur at the Pt electrode surface. But electrons are building up at the Pt surface...causing charging of the double layer. But these electrons cannot build up for ever...what happens when no redox reaction can happen and electrons keep building up? Am I making any sense?
Chemistry news on Phys.org
Is your solution saturated with atmospheric oxygen?
I don't think so...it is just buffer at room temp and at standard pressure. So, now I am thinking there will not be any current through the electrolyte at low voltages. There may be an initial charging current (double layer charging) when you increase the voltage from 0...but after that, no current because no redox reactions can take place. Correct?
If you are not sure, and if it is in contact with the air, it IS saturated with atmospheric oxygen. Oxygen removal is an important step in many electrochemical techniques, as it gets reduced at +0.4V.
I am not stating this is your problem, but it is a thing worth of checking.
I see...thanks for that info...that could certainly happen at 0.4 V, barring any overpotential.
So, at lower than 0.4 V, where would the current come from? Because I do see continuous current, even as low as 0.1 V (although at a lower level...current scales with the applied voltage). The current is quite low...picoamps, but its there. If it is just double layer charging, then the current should stop after about 3 time constants...but it doesn't...its continuous and steady...and I know it can't be electrons going through solution continuously...very intriguing...
How pure are the Pt, Si and SiO? There may be side reactions?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
