Determ the stationary temp with a PDE
  • Thread starter Thread starter Larsson
    Pde
The discussion focuses on determining the stationary temperature distribution within a square area subjected to boundary conditions defined by the surrounding temperature T_0 and a varying top boundary T_0(1+sin(pi*x/a)). The solution for the temperature u(x,y) is expressed as a product of functions, u(x,y) = sum(X(x)*Y(y)), where X(x) is identified as sin(k*pi*x/a). The heat equation in two dimensions is utilized, leading to the separation of variables and the formulation of the solution as u(x,y)=∑B_m*sinh(mπy)*sin(mπx), with boundary conditions applied to derive coefficients B_m in a Fourier sine series.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with Fourier series and boundary value problems
  • Knowledge of heat equations in two dimensions
  • Basic concepts of separation of variables technique
  • Study the method of separation of variables in PDEs
  • Learn about Fourier sine series and their applications
  • Explore the heat equation and its stationary solutions
  • Investigate boundary value problems in mathematical physics
Mathematicians, physicists, and engineers working with heat transfer problems, particularly those interested in solving partial differential equations and analyzing temperature distributions in bounded domains.
Larsson
I have a square area with the length a. The temperature surrounding the square is T_0 except at the top where it's T_0(1+sin(pi*x/a)). They ask for the stationary temperature in the area. In other words, how can the temperature u(x,y) inside the area be written when the time = infinity.
The first thing I do is that I realize that u(x,y) can be written u(x,y) = sum(X(x)*Y(y)).
I also think that it should be a nice starting point to create v = u-T_0, that gives me that the surrounding temperature is 0 everywhere except at the top where it's T_0*sin(pi*x/a)
experience tell me that X(x) = sin(k*pi*x/a)
But how do I find Y(y)? can't seem to get it right.
Start with the heat equation in 2dimensions, with du/dt=0 because you want the stationary solution. Let u(x,y)=X(x)Y(y) and put it into the p.d.e.
Then you separate variables.
X''/X=-Y''/Y=-\lambda^2
with cos/sin and exponential solutions. The homogenous boundary conditions eliminatate some of the constants.
and you end up with something like
u(x,y)=\sum_{m=0}^\infty B_m*sinh(m\pi y)*sin(m\pi x)
u(x,a)=\sum_{m=0}^\infty[B_m*sinh(m\pi a)]*sin(m\pi x)
where B_m*sinh(mpia) are the coefficients in a Fourier sin-series
