Determination of planck's constant
9 replies · 15K views · last reply
Ry122
I have a graph of voltage verse frequency.
Given that the charge of an electron = 1.6 x 10^-19 I need to obtain an estimate of the value Planck's constant. What equation do I need to use? Do I find the gradient of the graph?
What is the experiment that led to these measurements (this graph)?
[I have a guess... but you should really describe it.]
its the stopping voltage versus frequency for a metal surface.
The only part of the graph shown is from 5.4 to 6.8 f(X 10^14) and .26 to .85 volts. The graph is linear.
the work done in stopping the electron is equal to the kinetic energy lost...
that is,
[itex]eV_s=\frac{1}{2}mv^2[/tex]<br /> <br /> so from [itex]hf=hf_0+\frac{1}{2}mv^2[/itex]=>[itex]hf=hf_0+eV_s[/itex]<br /> <br /> rearrange and make it into the form you want...[/itex]
How can I solve for h when h is on both sides of the equation?
[itex]eV_s=hf-hf_0[/itex]
[itex]V_s=\frac{h}{e}f-\frac{h}{e}f_0[/itex]
Y=MX+C, can you see what M and C are?
I can't see what they are.
The values are
m = .421428
c = -2.2757 x 10^14
Well from [itex]V_s=\frac{h}{e}f-\frac{h}{e}f_0[/itex]
if a graph of [itex]V_s[/itex] and f is drawn, then the gradient,m. would be equal to the fraction: [itex]\frac{h}{e}[/itex] and so you know what e is, find h
I tryed this but but solving for h in m=h/e does not give Planck's constant.
Are you being careful with your units when you are calculating your gradient?
Remember that your frequency scale will probably be (x 10^14) Hz
You should get a much smaller gradient.
