Determine half life from gamma radiation
The discussion revolves around determining the half-life of an element through the study of gamma radiation emitted from its daughter isotopes following beta decay. The original poster is seeking guidance on how to relate gamma radiation to the half-life, expressing uncertainty about the timing of photon emissions and the connection to the parent isotope's decay.
  • Participants discuss the relationship between beta decay and subsequent gamma radiation, questioning how to account for the timing of photon emissions. There are inquiries about measuring energy to identify isotopes and how to relate these measurements to half-lives.
Participants have provided insights into the nature of gamma transitions and the potential for using energy measurements to identify isotopes. The original poster is considering consulting an assistant for further clarification, indicating an ongoing exploration of the topic.
The original poster mentions studying two isotopes simultaneously and expresses concern about the complexity of distinguishing between photon emissions from different nuclei. There is also a reference to the limitations of the course scope regarding the topic.
alivedude
I'm working on a lab and the task is to determine the half life of an element studying the beta radiation or the gamma radiation (emitted from the daughter). I have all the data and I'm done with the beta part, that was pretty straight forward. I have no clue how to relate the gamma radiation to the half life. This is how far I have come:
When a nucleus decays (in this case beta) it often leaves the daughter in an excited state. The daughter lowers it's energy by emitting photons but this doesn't necessary happens instant, right? So I can't count the photons and use the same equation as for beta radiation?
I don't even understand how I can relate the radiation from the daughter to the half life of the parent? I just need a push in the right direction.
Cheers! :)
Depends on the isotope. As an example, if your beta decay has a half-life of 1 year, and the gamma decay has a half-life of one nanosecond, you can assume it to be instantly. Most gamma transitions happen even faster, just a few metastable nuclei have relevant lifetimes.
In general, the distribution of the gamma radiation will depend on both lifetimes (or even more if you have more than one gamma transition). If you know the distribution well enough, you can measure both at the same time. In practice, that will rarely work, so you need some approximation or other external input.
Hmm okay, thanks!
I think I need to ask my assistant about this because it sounds a bit beyond our scope in this course. Because I know there is several gamma transitions in my isotopes and I'm studying two isotopes at the same time, how should I know which photons that comes from what nucleus? Can I measure their energy and go from that in somehow?
If you have a detector that can measure the energy: sure. Those transitions usually have well-defined energies (if they don't, then they are really shortliving), and you can look them up.
Yeah we have such a detector in the lab and I found decay schemes so I know their transitions energies. But I still don't understand how you can relate these energies to the half-lifes?
Well, with the energy you can figure out which isotope lead to the decay, and then you can study how the rate changes over time (if the lifetime is short enough) or find a relation between total activity and sample size (if the lifetime is too long to observe the reducing decay rate over time).
It was actually much easier than I thought. After some checking the decays schemes I noticed that it was only one photon per isotope and it was emitted in nano seconds, so I could only count the photons basically. I just overcomplicated it all :) Thanks anyway for the help!
  • · Replies 20 ·
