Determine if sequence converges or diverges n/(n-2)
  • Thread starter Thread starter isukatphysics69
    Sequence
The sequence defined by the expression n/(n-2) diverges as n approaches infinity. The correct approach involves recognizing that n!/(n-2)! simplifies to n(n-1), leading to the conclusion that the limit diverges to infinity. Additionally, when applying the limit comparison test to the series n/(8n^3+6n^2-7), using n/8n^3 as a comparison series demonstrates convergence due to the p-series test, where p > 1. This analysis confirms the importance of selecting appropriate comparison series in convergence tests.
  • Understanding of factorial notation and simplification techniques.
  • Familiarity with limits and their properties in calculus.
  • Knowledge of convergence tests, specifically the limit comparison test.
  • Basic understanding of p-series and their convergence criteria.
  • Study the properties of limits, focusing on how to evaluate limits at infinity.
  • Learn more about the limit comparison test and its applications in series convergence.
  • Explore p-series and their convergence criteria in detail.
  • Practice simplifying factorial expressions and applying them to sequences and series.
Students preparing for calculus exams, particularly those focusing on sequences and series, as well as educators teaching convergence tests and limit properties.
isukatphysics69
in title
n = 2,3,4...
n!/(n-2)! = n!/(n!(n-2)) = 1/(n-2) lim n->∞ = 1/∞ = 0 so sequence converges
Incorrect
isukatphysics69 said:
in title
n = 2,3,4...
Incorrect
Your first equality is wrong. Write out both the numerator and denominator of your original fraction.
i don't understand, so the original is n!/((n-2)!)
so i thought i can factor out an n! from the denominator?
Write out the factors of both numerator and denominator to see what cancels.
using n = 10 as an example
(10*9*8*7*6*5*4*3*2*1)/(8*7*6*5*4*3*2*1) leaving just 10*9 = means diverges at infinity
Yes, but now do it for general n, especially if this is a homework problem you are going to hand in.
There is no factor of n! in the denominator.
Also, this isn't a good way to write things.
As you wrote it, it looks like you factored 1/(n - 2) out of the limit expression. This isn't valid, because the limit is as n is changing. What you wrote is a little like writing 25 √, with nothing under the radical.
One last thing -- ∞ can't be used in arithmetic expressions, so 1/∞ is meaningless. However, you can say ##\lim_{n \to \infty} \frac 1 n = 0##.
This is not a homework, i am studying for final exam. but general n i will attempt quickly so i would say
(2*3*4*5*6...*n)/(1*2*3*4*5*6...(n-2))
cancel out everything until n leaving just
n!/(n-2)! where n!>(n-2)! so diverges?
Which makes it schoolwork.
n!/(n-2)!
No -- that's what you started with. After your simplification, how do you end up with the same thing you started with?
wait i mean it will leave just
n/(n-2) after the factorials cancel
No.
Isn't n! = n(n - 1)(n - 2)! ?
Mark44 said:
No.
yes, so n(n - 1)(n - 2)! / (n-2)!
so cancel the (n-2)! leaving just n(n-1)
Yes. Now wasn't that easier?
So ##\lim_{n \to \infty}\frac{n!}{(n - 2)!} = \lim_{n \to \infty} n(n - 1) = ##?
And what does this say about your sequence?
so that would be inf * inf so the sequence diverges
Yes
Mark44 said:
Yes
hey do you agree with what i am doing here to prove that the series n/(8n^3+6n^2-7) converges, i am using a limit comparison test n^2/(8n^3+6n^2-7)
i will now take the limit at infinity so i only care about the leading terms
n2/8n3 so lim n approaching inf of n/(8n) = 0. this shows that a larger series converges since the infinite limit 0 so the smaller original series also converges
No, I don't agree. When you use the limit comparison test, you are comparing the series you're working with against another series whose behavior you know.
The series you picked to compare against is a divergent series, being comparable to ##\sum \frac 1 n##, or more specifically, ##\sum \frac 1 {8n}##, which also diverges. I'm pretty sure you didn't know that.
You should rethink the series you're going to compare against.
ok, ill be back
wow, i think i can just use n/8n^3 as my comparison series. this would be 1/8n^2 which by the p series test i know converges since p>1
n/8n^3 > n/(8n^3+6n^2-7)
since the larger one converges, the smaller one must also converge
Much better choice.
Sure, that works.
You could also use the limit comparison test, comparing your series against ##\frac 1 {8n^2}##, which you know converges, being a multiple of a convergent p-series..
Your reasoning was much better this time. These problems about convergence/divergence are basically true/false questions, where you would have a 50% chance of getting it right merely my guessing. To show you really understand, you have to provide solid reasoning.
i have another one here that i think i solved proper but unsure.
from n=1 to inf
(cos(n*pi)) / (n^2)
|cos(n*pi)| <= 1
by comparison i can take the series 1/(n^2) which is > (cos(n*pi)) / (n^2)
by the p series test 1/(n^2) converges since p > 1
so by comparison (cos(n*pi)) / (n^2) must converge absolutely since |(cos(n*pi))| / (n^2) < 1/(n^2)
from n=1 to inf
(cos(n*pi)) / (n^2)
|cos(n*pi)| <= 1
Since this is a new problem, please start a new thread.
Thread closed.
  • · Replies 17 ·
  • · Replies 34 ·
