Determine if you have enough information to figure question.
  • Context: MHB
  • Thread starter Thread starter clhrhrklsr
    Figure Information
The discussion revolves around determining whether sufficient information is provided to solve specific geometry problems, particularly involving triangles and the application of the Law of Sines. Participants seek clarification on how to approach these problems and share their reasoning and methods.
  • Homework-related
  • One participant expresses uncertainty about how to begin solving practice problems and asks for guidance on determining if enough information is available.
  • Another participant asserts that two known pieces of information are necessary to solve for an unknown side or angle in a triangle, indicating that the initial problem lacks sufficient data.
  • A participant discusses a second problem involving two angles and a height, questioning whether this provides enough information to find the length of a side of the triangle.
  • One participant describes using the Law of Sines to solve the second problem, explaining the relationship between angles and sides in a triangle.
  • Another participant expresses a lack of familiarity with the Law of Sines and requests a detailed explanation of how to apply it to the problem.
  • Participants discuss the calculation process, including how to input values into a calculator to find the unknown side length.
  • A new problem is introduced regarding the number of screws required for a gutter installation, but the syntax of the question raises confusion among participants.
  • Some participants express a desire to seek additional input from others to clarify the gutter problem.
There is no consensus on the initial problem's sufficiency of information, as some participants agree that more data is needed while others explore the application of the Law of Sines. The discussion on the gutter problem remains unresolved, with participants expressing confusion about its wording.
Participants have varying levels of familiarity with the Law of Sines and calculator usage, which may affect their ability to solve the problems presented. The syntax of the gutter problem is unclear, leading to further questions.
Students working on geometry problems involving triangles, particularly those unfamiliar with the Law of Sines, as well as those seeking assistance with problem-solving strategies in mathematics.
clhrhrklsr
I have typed/handwritten a couple of practice problems similar to ones I've seen before. View attachment 2800
Could anyone tell me how to figure these? I don't even know where to begin on solving these. How do you begin to determine if you have enough information.
Thanks in advance for any help!
Mathematics news on Phys.org
No there's not enough information. When trying to solve for an unknown side or angle, you need TWO known pieces of information. Here you only have one.
Thanks! I believe I'm on the right track.
On page 2 of my attachment, I have a 2nd question.
Here the practice question gives me 2 angles (90 degrees and 67 degrees). It also gives me a height of 10'-0". It asks if there is enough information given to find the length of side C (the slope of the triangle).
As you said in your reply, you need to have 2 known pieces of information.
Since this triangle has 2 known angles and the height, how do you know if you have enough info to get "C"?
Hello! I did the Law of Sines for the second problem. Since this is in the algebra section, I guess you haven't gone over this before (?) If you would like me to work it out the Law of Sines way, I'd be happy to! :cool:
That would be great. I haven't went by any problems like these before and I'm trying to figure them out. I have never worked problems with the Law of sines before, and I wasn't sure how to even begin that second problem.
Thanks
Sure thing! :cool: The Law of Sines is a ratio. The neat thing about this law is that it works for ANY triangle. It's a secret that those geometry teachers forbid to tell their students :D
The formula for the law of sines is $$ \frac{a}{sin(A)} = \frac{b}{sin(B)} = \frac{c}{sin(C)}$$
The angles are represented by the upper case letters, while the lower case letters are the side of the triangle, as seen in the image below.
So in your second image, you have two angles, the first being 90 degrees, and the second 67. Since a triangle is known to have 180 total degrees, we subtract 90 and 67 to get our third angle:
$$180-90 = 90$$
$$90-67 = 23$$
So all three angle values are known now, which are 90, 67, and 23 degrees. :)
We have one known value of length, which is all we need. That is the value of 10 ft, which is OPPOSITE of our angle that measures 23 degrees. This means that we have enough information to solve for the remaining sides. So now we set up the ratio. I figure there is more than one way to do it, but this is how I do it. We have both a values (Both uppercase and lowercase a. I'm calling the distance of 10 feet lowercase a and the value of 23 degrees uppercase A because they are opposite of each other in your diagram and as shown in the image above). So, let's see what we have:
$$\frac{10}{sin(23)} = \frac{c}{sin(90)}$$
The angle C is 90 degrees because it is opposite of the value c that you are trying to find in the diagram. :)
So now, we just treat this as a typical ratio and solve for c:
A pretty handy thing to know in trigonometry and even geometry is that the sine of 90 degrees = 1. So now, we'll rewrite:
$$\frac{10}{sin(23)} = \frac{c}{1}$$
Now we cross multiply:
I'm going to multiply 1 by 10 (Diagonal to each other), then divide by $$sin(23)$$ . This will give us our answer:
$$1*10 = 10$$
$$\frac{10}{sin(23)} = c$$
Approximately equals 25.59304665
If you have any questions, or would like to see the other side done as well, I'd be happy to!:cool:
https://www.physicsforums.com/attachments/2826
$$180-90 = 90$$
$$90-67 = 23$$
$$1*10 = 10$$
That helped a lot. Here is where I got lost.
How do I input the "sin(23)" in my calculator (HP 48G+)? I tried hitting 23 then my sin button and I get a weird decimal number. And then when I divide that by the 10, it lowers that decimal? Can you please tell me what I am doing wrong?
I would type (In calculator terms) :
(10/(sin(23)))
*And make sure your measure is in degrees, not radians...The answer should match above :)
(10/(sin(23)))
That worked! Thank you.
Now if you don't mind, lol, I need help on only one other problem. I am asked this on a practice question-
On a 100' - 0" (100 feet 0 inches) long building, how many screws are required to screw gutter to the building 12" (12 inches) off center (O/C)?
Is there a picture to go along with it, or is that all you have?
No picture. Its just worded the way I typed it. I'm assuming a trick question.
I won't lie, the syntax of that problem question isn't clicking with me. I'm going to ask a couple of others here to have a look at it, and see what they think, so that we can get the answer for you as soon as possible!
In the meantime, if the problem is written in ink on a worksheet or textbook, would you care to put a picture of it on here?
We WILL get your answer solved for you! :cool:
It was just a word problem on a practice test. Its a trick question I suppose to see if you can work the problem without a picture to go by.
  • · Replies 34 ·
