Determine resolution of use by modelling it as single slit
The problem involves modeling the pupil of the eye as a single slit to determine its ability to distinguish two objects separated by a small angle, given specific parameters such as wavelength and diameter.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of intensity equations and the implications of using the pupil's diameter as the slit width. There is uncertainty about how to incorporate the intensity change into the calculations and how to approach the problem with two sources.
The discussion is ongoing, with participants attempting to clarify the setup and the equations needed to analyze the problem. Some guidance has been offered regarding the interpretation of the intensity equation and the consideration of multiple sources.
Participants note the importance of the intensity change threshold and the specific angle separation required for the problem, which are central to the calculations but may not be fully resolved in the discussion.
twinklestar28
Model the pupil of the eye using a single slit. If the eye is able to notice changes in intensity of 20% show that it can distinguish two objects separated by an angle of 0.00015 radians if =500nm and diameter=4mm.
I=Iosin^2((π/λ)asinθ)/ ((π/λ)asinθ)^2
sin θ=λ/a
I attempted to find a (width) from the intensity equation but it doesn't seem to work, so I am unsure of how to start the calculation, the question is worth 4 marks, any help would be appreciated :)
sin θ=λ/a
Looks like for the slit width you are to use the diameter of the pupil ("Model the pupil of the eye using a single slit")
You wrote I(θ) for a slit illuminated by a single source. You need to account for the fact that there are two sources, separated by an angle of 0.00015 radians.
O ok so the equation would be
I=Iosin^2((π/λ)asinθ-∅)/ ((π/λ)asinθ-∅)^2
it gives a hint to consider the intensity halfway between the peaks of the two images so i did
((π/λ)asin(θ-∅)) = ∏/2
but where do i put the intensity change of 0.2% to get (θ-∅) = 0.00015?
That's the intensity of a single source that is located an angle ∅ away from the central axis.
But we have two sources. Let's say one of them is an angle ∅ away from the central axis, and one of them is on the central axis. You need to consider the intensity due to each source, and combine them to get the intensity in the combined diffraction pattern.
Hello, I am fairly new here. I posted one new question but I forgot how to do that. Can anybody assist me by telling me how to post a new question?
9K
