Determine the Forces in the Specified Members.
  • Thread starter Thread starter Northbysouth
    Forces Members
1 reply · 8K views
Northbysouth
Determine the forces in members BC, CF, and EF of the loaded truss. Forces are positive if in tension, negative if in compression.
I have included an image
ƩM = 0
ƩFy = 0
ƩFx = 0
I'm a little stuck on this one.
I tried using method of sections, whereby I drew a line through the middle of lines BC, CF and EF and then focused on everything to the right of that line. What this gave me is a system with two L forces, one at E and another at D as well as the forces of the members BC, EF and CD.
From here I tried to take the moment about point C,
ƩMC = 0
0 = -L(d) + EFcos(17)
however I ran into difficulty because I couldn't figure out what the distance of CE is.
Help would be appreciated
ƩM = 0
ƩFy = 0
ƩFx = 0
ƩMC = 0
0 = -L(d) + EFcos(17)(length of CE)[/color]
It's just a bit of trig and geometry to find the distance CE. The length 'd' is known and a couple of the angles...find the vertical legs of triangles with side d and angle theta...draw a sketch...otherwise, your equation is good when you add your omission noted in red
