Determine the magnitudes and directions of the currents in each R's.
The discussion focuses on calculating the magnitudes and directions of currents in a circuit with two batteries and three resistors. The batteries have electromotive forces (emfs) of 9.1 V and 11.6 V, while the resistors are valued at 15 Ω, 33 Ω, and 30 Ω, with each battery having an internal resistance of 1.3 Ω. The participant initially calculated currents I1, I2, and I3 but received incorrect feedback from Mastering Physics, prompting a review of their calculations. The primary issue identified was the incorrect addition of internal resistance to R2, which is not in series with either battery.
  • Understanding of Ohm's Law and EMF equations
  • Familiarity with Kirchhoff's Junction Rule
  • Basic knowledge of series and parallel circuits
  • Experience with circuit analysis software or tools
  • Review circuit analysis techniques using Kirchhoff's Laws
  • Practice calculating currents in circuits with internal resistance
  • Explore the use of simulation tools like LTspice for circuit verification
  • Learn about the impact of internal resistance on circuit performance
Students studying electrical engineering, physics enthusiasts, and anyone involved in circuit analysis and troubleshooting.
NasuSama
Determine the magnitudes and directions of the currents in each resistor shown in the figure. The batteries have emfs of ##\varepsilon_1 = 9.1## V and ##\varepsilon_2 = 11.6## V and the resistors have values of ##R_1 = 15 \Omega## , ##R_2 = 33 \Omega## , and ##R_3 = 30 \Omega## .
Assume each battery has internal resistance ##1.3 \Omega##.
EMF equation: ##\varepsilon = IR##
The equations for this case are:
##\varepsilon_1 = I_1(R_1 + r) + I_2(R_2 + r)##
##\varepsilon_2 = I_3(R_3 + r) + I_2(R_2 + r)##
where ##r## is the internal resistance. I know that by junction rule, ##I_2 = I_1 + I_3##
I found that ##I_1 \approx 0.092## and ##I_3 \approx 0.13##. For ##I_2##, the value is approximately 0.22 in terms of two significant figures, but Mastering Physics marked it incorrect, indicating that I need to check my calculations. I don't know what I did wrong. 0.23 and 0.21 are also incorrect.
The thing here is that I still get the same calculations over and over again, but Mastering Physics marked it wrong for no reason. Will anyone check the calculation? Thank you!
Why would you add the internal resistance of the battery to R2? R2 is not in series with either battery. Otherwise, your equations look okay. Fix the battery resistance issue and I think you'll be okay.
  • · Replies 17 ·
  • · Replies 30 ·
