Determine the points where the net magnetic field is zero
7 replies · 3K views · last reply
jisbon
A long straight wire lying along x axis carries current I in positive x direction.
Another long straight wire lying along y axis carries current I/3 in positive y direction.
Find points where net magnetic field is zero.
Unsure about this, but here is my attempt:
B from the first wire: ##\dfrac {\mu _{0}I}{2\pi r} ##
B from the second wire: ##\dfrac {\mu _{0}I}{2\pi r} ##
Let the point be (x,y)
Can I state that: ##\dfrac {\mu _{0}I}{2\pi y}+\dfrac {\mu _{i}\left( I/3\right) }{2\pi x}=0##
Hence the magnetic field is zero whenever x= -1/3y?
Thanks
jisbon said:
Homework Statement:: A long straight wire lying along x-axis carries current I in positive x direction.
Another long straight wire lying along y-axis carries current I/3 in positive y direction.
Relevant Equations:: -
Thanks
The magnetic field is a vector. You need the vector sum to be zero.
So for example in the wire on y axis, can't I assume it will only affect the x direction as the y direction is simply canceled out?
Certainly the field due to that wire nowhere has a y component. What does that leave?
So that leaves a x component, while the wire at the x-axis only leaves the y component, hence the equation I put in my thread whereby:
I do not read the question as restricted to a plane.
Besides, an x component cannot cancel a y component.
So the x component must be equals to 0 too? since the point I am trying to find has no magnetic field
Yes, but but what about my other point? The Newtonian world has three dimensions.
