Determine the wave function of the particle
rmfw
[STRIKE][/STRIKE]
A particle coming from +∞ with energy E colides with a potential of the form:
V = ∞ , x<0 (III)
V = -V0 , 0<x<a (II)
V = 0, x>a (I)
a) Determine the wave function of the particle considering that the amplitude of the incident wave is A. Writting the amplitude of the reflected wave at x=a in the form
[itex]\frac{B}{A} = e^{i\delta}[/itex]
determine [itex]\delta[/itex] . What is the value of [itex]\delta[/itex] in the limit where V0 = 0 ?
b) Determine the probability density current in x>a
a)
For region I :
[itex]\Psi_{I} (x) = Ae^{-ikx} + Be^{ikx} , k=\frac{\sqrt{2mE}}{\hbar}[/itex]
II:
[itex]\Psi_{II} (x) = Csin(lx) + Dcos(lx) , l=\frac{\sqrt{2(mE+V_{0}}}{\hbar}[/itex]
III:
[itex]\Psi_{III} (x) = 0[/itex]Boundary conditions:
at x=0:
[itex]0 = Csin(lx) + Dcos(lx) (=) D = 0[/itex]
So [itex]\Psi_{II} (x) = Csin(lx)[/itex]
at x=a:
[itex]Ae^{-ika} + Be^{ika} = Csin(la)[/itex] (1)
and
[itex]-ikAe^{-ika} + ikBe^{ika} = lCcos(la)[/itex] (2)
Dividing (1) for (2) I got:
[itex]\frac{B}{A} = e^{-2ika} \frac{(-\frac{1}{l}tan(la)ik-1)}{(1-\frac{1}{l}tan(la)ik)}[/itex]
How can I get rid of that constant that is multiplying by the exponential? Is this even right?
B/A appears to be a complex number - is that right?
Note: did you try writing ##\psi_{II}## as a sum of complex exponentials?
Hi Simon Bridge, thank you for your reply.
I did write psiII as a sum of complex exponentials and I got the following:
[itex]\frac{B}{A} = \frac{\frac{k}{l}e^(ika-ila)-\frac{k}{l}e^(-ika + ila) - e^(-ika -ila) - e^(-ika + ila)}{\frac{k}{l}e^(ika-ila) - \frac{k}{l}e^(ika+ila) +e^(ika+ila) + e^(ika-ila)}[/itex]
is there any way to simplify this ? This problem is killing me, because I'm not even sure what "writing the amplitude of the reflected wave at x=a in the form [itex]\frac{B}{A}[/itex] " means.
I mean, I assumed the amplitude of the reflected wave at x=a is B, if I write B/A it isn't the amplitude of the reflected wave anymore.
B/A is the proportion of the incident amplitude that is reflected.
If you multiplied it by 100, you's be able to say, "100B/A percent got reflected".
You basically have to look for common factors and cancel things off a bit at a time.
It is not going to be easy. But that, I am afraid, is the exercise.
Note: ##e^{a-b}+e^{-a-b}=(e^a+e^{-a})e^{-b}## ... stuff like that. maybe ##e^{-b}## cancels something in the denominator? If not - look for something else.
Of course, since they are all constant terms, it may be possible to add them up geometrically.
Separate the real and imaginary components.
