Determine whether the PDF converges in distribution
8 replies · 3K views · last reply
cwbullivant
Let $$ \it{f}(x) $$ be a probability density function. Now let Xn have the density:
$$ \it{f}_{n}(x) = n\it{f}(nx) $$
Determine whether or not Xn converges in distribution to zero.
(this is the verbatim statement, there is no additional information given)
[/B]
If the CDF $$ F_{n}(X) \rightarrow 0, n \rightarrow \infty $$ then Xn converges to zero in distribution.
Definition of CDF:
$$ F_{n}(x) = P (X < x) = \int_{-\infty}^{x} \it{f}_{n}(x) dx= \int_{-\infty}^{x} n\it{f}(nx) dx $$
And to be a valid PDF, its integral from -∞ to +∞ must be 1. That requires that f(nx) must go to zero as nx goes to ±∞. So the lower limit on that integral is already taken care of; that part has to vanish if nf(nx) is going to be a valid PDF.
But for finite x, wouldn't the behavior of f(nx) as n goes to ∞ depend on exactly what f(nx) looks like (e.g. would go to zero if f(nx) = e^{-nx}, but not if f(nx) = ne^(-x))? I'm not sure on where to go from here.
[/B]
Definition of CDF:
Re-write ##F_n(x)## by changing variables to ##u = nt## in ##\int_{-\infty}^{x} n f(nt)\, dt##. Note: do NOT ##\int^x f(x) dx##; you should never, ever use the same symbol '##x##' to stand for two totally different things in the same expression---once as the integration variable, and once as the upper integration limit).
Edit: Ok, I think I've written too much. First follow the hint of the post above.
cwbullivant said:
Definition of CDF:
$$ F_{n}(x) = P (X < x) = ... $$
This is wrong. A CDF is actually defined as ##F(x) = P\big( X\leq x \big)##.
It's a technical but important distinction. A CDF is alway right continuous . This matters when you start dealing with CDFs involving discrete r.v.'s, hybrids, etc.
Some books and papers (mostly old, now) actually define the CDF using "<". Probably 99.9% of sources nowadays use "≤", but I am not sure we can positively assert that "<" is wrong. (Maybe the OP's textbook and/or course notes take the "<" definition---unlikely, I know, but just barely possible.) However, I realize that many students are sloppy, and write "<" when they really mean "≤", so pointing it out to them is good!
Sloppiness is exactly the issue here.
Anyhow, I make the appropriate substitution, with u = nt, du = n dt, and come out to:
$$ \int_{-infty}^{nx} \it{f}(u) du $$
This has eliminated the linear dependence on n from the original statement and reduced the problem to an integral with just a function in the integrand. From here, I don't seem to see much improvement. Whether or not the outcome of the integral goes to zero as n goes to infinity still seems like it should depend on the actual structure of f(u).
It was tempting to say that since the upper bound is u=nx, which is linear in n (which generally doesn't bode well for a finite answer as n goes to infinity), the PDF does not converge in distribution, but that doesn't sound right to me, because I don't see a good way to make that kind of conclusion from the integral of a completely general f(u).
You can deduce the behavior of ##f(y)## for ##y \rightarrow \infty##, namely ##f## should decrease faster than ##\frac{1}{y}##.
You are having trouble because you are using the wrong convergence criterion! Your stated criterion would be for ##X_n \to +\infty##, not the ##X_n \to 0## posed in the question.
Recall the true definition: ##X_n \to X## in distribution if ##F_n(x) \to F(x)## for all ##x## (or, at least, for most ##x##). What is the CDF ##F(x)## for ##X = 0## (the identically-zero random variable)?
## F(x) = P(0 \leq x) = 1, x \geq 0, 0 otherwise##?
