Determine whether the PDF converges in distribution
  • Thread starter Thread starter cwbullivant
    Distribution Pdf
The problem involves determining whether a sequence of random variables \( X_n \), defined by the probability density function \( f_n(x) = n f(nx) \), converges in distribution to zero. The context is rooted in probability theory and the properties of cumulative distribution functions (CDFs).
  • Participants discuss the definition of the CDF and its implications for convergence in distribution. There are attempts to rewrite the CDF using variable substitutions and to analyze the behavior of the integral as \( n \) approaches infinity. Questions arise regarding the dependence of the outcome on the specific form of the function \( f \).
The discussion is ongoing, with participants exploring different aspects of the problem, including the correct definition of the CDF and the implications of the convergence criteria. Some guidance has been provided regarding the substitution of variables and the need to clarify the convergence criterion relevant to the problem.
There is a noted concern regarding the use of "<" versus "≤" in the definition of the CDF, which may reflect varying conventions in different sources. Additionally, the discussion highlights the importance of the behavior of \( f(u) \) as \( u \) approaches infinity in determining convergence.
cwbullivant
Let $$ \it{f}(x) $$ be a probability density function. Now let Xn have the density:
$$ \it{f}_{n}(x) = n\it{f}(nx) $$
Determine whether or not Xn converges in distribution to zero.
(this is the verbatim statement, there is no additional information given)
[/B]
If the CDF $$ F_{n}(X) \rightarrow 0, n \rightarrow \infty $$ then Xn converges to zero in distribution.
Definition of CDF:
$$ F_{n}(x) = P (X < x) = \int_{-\infty}^{x} \it{f}_{n}(x) dx= \int_{-\infty}^{x} n\it{f}(nx) dx $$
And to be a valid PDF, its integral from -∞ to +∞ must be 1. That requires that f(nx) must go to zero as nx goes to ±∞. So the lower limit on that integral is already taken care of; that part has to vanish if nf(nx) is going to be a valid PDF.
But for finite x, wouldn't the behavior of f(nx) as n goes to ∞ depend on exactly what f(nx) looks like (e.g. would go to zero if f(nx) = e^{-nx}, but not if f(nx) = ne^(-x))? I'm not sure on where to go from here.
[/B]
Definition of CDF:
Re-write ##F_n(x)## by changing variables to ##u = nt## in ##\int_{-\infty}^{x} n f(nt)\, dt##. Note: do NOT ##\int^x f(x) dx##; you should never, ever use the same symbol '##x##' to stand for two totally different things in the same expression---once as the integration variable, and once as the upper integration limit).
Edit: Ok, I think I've written too much. First follow the hint of the post above.
cwbullivant said:
Definition of CDF:
$$ F_{n}(x) = P (X < x) = ... $$
This is wrong. A CDF is actually defined as ##F(x) = P\big( X\leq x \big)##.
It's a technical but important distinction. A CDF is alway right continuous . This matters when you start dealing with CDFs involving discrete r.v.'s, hybrids, etc.
Some books and papers (mostly old, now) actually define the CDF using "<". Probably 99.9% of sources nowadays use "≤", but I am not sure we can positively assert that "<" is wrong. (Maybe the OP's textbook and/or course notes take the "<" definition---unlikely, I know, but just barely possible.) However, I realize that many students are sloppy, and write "<" when they really mean "≤", so pointing it out to them is good!
Sloppiness is exactly the issue here.
Anyhow, I make the appropriate substitution, with u = nt, du = n dt, and come out to:
$$ \int_{-infty}^{nx} \it{f}(u) du $$
This has eliminated the linear dependence on n from the original statement and reduced the problem to an integral with just a function in the integrand. From here, I don't seem to see much improvement. Whether or not the outcome of the integral goes to zero as n goes to infinity still seems like it should depend on the actual structure of f(u).
It was tempting to say that since the upper bound is u=nx, which is linear in n (which generally doesn't bode well for a finite answer as n goes to infinity), the PDF does not converge in distribution, but that doesn't sound right to me, because I don't see a good way to make that kind of conclusion from the integral of a completely general f(u).
You can deduce the behavior of ##f(y)## for ##y \rightarrow \infty##, namely ##f## should decrease faster than ##\frac{1}{y}##.
You are having trouble because you are using the wrong convergence criterion! Your stated criterion would be for ##X_n \to +\infty##, not the ##X_n \to 0## posed in the question.
Recall the true definition: ##X_n \to X## in distribution if ##F_n(x) \to F(x)## for all ##x## (or, at least, for most ##x##). What is the CDF ##F(x)## for ##X = 0## (the identically-zero random variable)?
## F(x) = P(0 \leq x) = 1, x \geq 0, 0 otherwise##?
  • · Replies 18 ·
