Determine whether vector field is magnetic or electrostatic
3 replies · 3K views
Roodles01
Three vector fields are listed below. Determine whether each of them is electrostatic field or magnetic field.
F1(x, y, z) = A (9yz ex + xz ey + xy ez)
F2(r,∅,z) = A [(cosx/r)er + (sinx/r) e∅]
F3(r,θ,∅) = Ar2 e(-r/a) er
Used matrix to determine the first one
| ex ey ez |
|δ/δx δ/δy δ/δz|
|yz xz xy |
as electrostatic (curl = 0 = -δB/δt) & fine with the how & what defines an electrostatic field
but . . . .
not sure how to determine whether one of these fields is magnetic or not!
Help please.
Thank you.
What do you know about the divergence of the electric and magnetic fields?
ehild
1. divergence should be proportional to the density of magnetic "charge" (div B = 0 - no monople law)
2. div E = ρ / E0
(and for a conservative (electrostatic) field the curl should be zero. (Faradays law - curl E - -∂B/∂t))
The difference is that I "get" 2 and can show this by the matrix I showed above, but not sure how to apply 1 to come to the conclusion of whether it's an electrostatic field or magnetic field.
Can I go down a similar route to find that divB = 0
OK, OK I've kicked off a bit early.
I will be using the equations booklet & make sure I look at it to complete problems in the way I've been taught (although coming back to it from a while ago dulls the mind if you're not using it).
