Determining distance of travel with friction acting on a car.
A car traveling at 51 mi/h on a wet highway with a static friction coefficient of 0.102 needs to determine the minimum stopping distance. The discussion highlights the use of kinetic equations and the relationship between friction and motion. Participants express confusion over the lack of mass and acceleration values in the problem, complicating the calculation of stopping distance. A free body diagram is mentioned, noting that it becomes more useful once the mass is recognized as canceling out in the equations. Ultimately, understanding the forces involved, including weight, normal force, and friction, is crucial for solving the problem.
quinntan
1. A car is traveling at 51 mi/h on a horizontal highway. If the coefficient of static friction between the road and tires on a rainy day is .102 what is the minimum distance in which the car will stop.
2. f=un f=ma kinetics equations
3. No idea here. Teacher barely skimmed over friction so far and all problems we have done in class either had a value of acceleration, a mass or a force. This one has none of those.
can u imagine what will happen to the car?
I know it will stop eventually but I don't know how far it will go. I made a free body diagram but it wasn't very useful without knowing the cars mass.
In your free body diagram, do u have these 3 forces:
the weight od the car, the normal force exerted by the ground, and the friction force? :)
Alright I got it. It turns out that the masses cancel.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
