Determining Series Convergence using the Ratio Test
The discussion revolves around using the Ratio Test to determine the convergence of the series ∑(n/(e^n)^2). The Ratio Test requires evaluating the limit of the ratio of consecutive terms, which leads to the expression e^{-(2n + 1)}. Participants clarify that if the limit approaches 0, the series converges, but confusion arises regarding the conditions for the test. Ultimately, one participant realizes they misremembered the conditions, noting that a limit of 1 is inconclusive, while a limit of 0 indicates convergence. The conversation highlights the importance of accurately applying the Ratio Test in series convergence problems.
BraedenP
I'm asked to specifically use the Ratio Test (formula below) to determine whether this series converges or diverges (if it converges, the value to which it converges is not needed.)
\sum_{n=1}^{\infty}\frac{n}{(e^n)^2}
Ratio Test:
If a_n is a sequence of positive terms, then the following conditions are true for the limit:
\lim_{n\to\infty}\frac{a_{n+1}}{a_n}
If lim<1, the series converges.
If lim>1, the series diverges.
If lim=1, inconclusive.
By simply plugging values into the formula and rearranging the resulting fractions, I get this form:
\frac{(e^n)^2(n+1)}{(e^{(n+1)})^2\cdot n}
From what I can see, applying L'Hopital's rule won't help get this limit into a solvable form, and no algebraic transformations pop out at me as being helpful.
How would one start solving this limit?
<br /> \frac{e^{n^2}}{e^{(n + 1)^2}} = e^{-(n + 1)^2 + n^2} = e^{-2n - 1}<br />
And to make that even more explicit
e^{-(2n + 1)}
Hmm.. I tried that method, but the limit evaluates to 0, which doesn't help when identifying convergence.
I could try a bunch of other tests on this series, but the assignment specifically says to use the Ratio Test. Any suggestions? Perhaps I could just say that I performed the Ratio Test, but it was inconclusive, so I used another method.
ORLY? Care to tell us what ratio test you are using?
I just factored out the term provided above, and got:
e^{-(2n+1)}\cdot(\frac{n+1}{n})
\frac{1+\frac{1}{n}}{e^{(2n+1)}}
And that approaches 0 as n\to\infty: \frac{1}{\infty}.
So, how is this inconclusive?
Because according to the Ratio Test, if the limit in this form equates to 0, then I can't say anything regarding the convergence of the series.
And when could you say that it converges or diverges?
I wrote the conditions of the Ratio Test in the OP. If the limit is greater than 1, we can say that it diverges. If it's less than 1, the series converges.
So, is zero greater than or smaller than one?
I think you mean "if the limit in this form equates to 1" then it's inconclusive.
OOPS! I memorized the theorem wrong! If it EQUALS 1, the test is inconclusive. Never mind.
Sometimes I wonder how I'm still alive after these retarded mistakes.
Thanks! You're a life saver :)
Edit:
Yeah, I figured that out a little too late. :P Thanks :)
