Determining supply voltage for an unmarked drill
4 replies · 2K views · last reply
gnurf
I've inherited a drill and I have no idea what voltage is required to run this thing. The image below displays all the information available. I've also unscrewed the top and found no clues inside. Ditto for the website. Long shot: Does anyone know what the supply voltage of this thing might be, or how I should go about finding it? I don't have an adjustable power supply, btw.
Thanks!
Photo of a silver handheld micro drill with a grey cable and a small chuck holding a thin bit, beside a metal ruler on a wooden table; inset shows a black cylindrical motor labelled CASATI CARLO AG, MASCHINENFABRIK, CH-9434 AU / SCHWEIZ.
Hi gnurf! :smile:
I just looked up what you have there.
It turns out the wording and numbers you have are just the name and address of the factory in Switzerland.
Then I looked up the supply voltage that is used in Switzerland, which is 230 V at 50 Hz.
This is the same as it is everywhere in Europe.
The only thing bothering me is the plug that's on it.
Plugs are always male and never female.
Is it possible you have an adapter to go with it?
According to wikipedia Switzerland normally uses plugs of type C and J.
And only in old installations type E.
But none of those appear to match the plug you have (that is female!? :confused:).
Photo of a black two-pin figure-eight style power cord plug with rounded pins, the type commonly used on appliance power leads.
http://upload.wikimedia.org/wikipedia/commons/thumb/2/2a/J_plug.jpg/100px-J_plug.jpg
Photo of a white wall socket with two round holes and a centre earth hole, next to a white wall-mounted power outlet with two round holes.
Hi I_Like_Serena, thanks a lot for your effort. After staring blankly at the drill for a while I realized there were more movable parts, and so I found this:
Grey cylindrical electric motor labelled MONOPERM SUPER 12V- max 1,5A, with two wires with lugs attached to its top end, lying on a wooden surface.
Case closed! :)
Case closed! :)
Hah! That looks a lot like an adapter.
Enjoy! :wink:
I would suggest starting by looking at the manual or product specifications for the drill. If those are not available, you can try reaching out to the manufacturer for more information. If that is not possible, you can try using a multimeter to measure the voltage of the battery or power cord that came with the drill. If you are still unable to determine the voltage, you can try consulting with an electrician or taking the drill to a hardware store for assistance. It is important to know the correct voltage in order to safely operate the drill and avoid damaging it. Good luck!
