Determining the absolute convergence, convergence, or divergence of a series.
The discussion revolves around determining the absolute convergence, convergence, or divergence of the series \(\Sigma_{n=0}^{\infty} \frac{(-10)^n}{n!}\). Participants explore various convergence tests, including the Comparison Test, Ratio Test, and Root Test, to analyze the series.
  • Participants discuss applying the Comparison Test and the Ratio Test, with some expressing uncertainty about which series to compare against. There are attempts to analyze the behavior of the series as \(n\) approaches infinity and considerations of how to manipulate the terms to find a suitable comparison.
Some participants have provided guidance on using the Ratio Test and have clarified that a series does not need to be greater for all \(n\), but only for sufficiently large \(n\). There is ongoing exploration of different series to compare and the implications of the tests being discussed.
Participants note challenges in finding an appropriate series for comparison and express confusion about the behavior of the series under different tests. The discussion reflects a mix of attempts and uncertainties regarding the application of convergence tests.
lilypetals
[tex]\Sigma[/tex] from n=0 to infinity (-10)n/n!
Determine the absolute convergence, convergence, or divergence of the series.
In this section, it's suggested that we use the following to determine a solution:
A series is called absolutely convergent if the series of absolute values [tex]\Sigma[/tex]|an| is convergent.
The Comparison Test, which states that if the series bn is convergent and greater than the series an, then the series an is also convergent; and if the series bn is divergent and less than the series an, then the series an is also divergent.
The Ratio Test, which states that if the limit as n goes to infinity of |an+1/an| is less than 1 the series is absolutely convergent; if it is greater than 1 the series is divergent; and if it is equal to 1 the Ratio Test is inconclusive.
The Root Test, which states that if the limit as n goes to infinity of the nth root of an is less than 1 the series is absolutely convergent; if it is greater than 1 the series is divergent; and if it is equal to 1 the Root Test is inconclusive.
I decided that the simplest method would be to apply the Comparison Test to the series of absolute values:
[tex]\Sigma[/tex] n=0 to infinity |(-10)n|/n!
So, I need to consider a bn which is greater than an, which converges.
This is where I get stuck. I haven't been able to find a bn for which I could solve the limit as n goes to infinity. Anyone have a good method for this?
Usually when you have n appears in factorials and in the exponent, the ratio test is a good one to try. That said, you can prove the series converges using the comparison test. What series have you considered and where do you get stuck with them?
I guess that's the problem--I'm not even sure which series to consider. I know that if I guess that the given series converges, I need a larger series which also converges, and I can meet the criteria by making the denominator smaller or the numerator larger. It's hard to imagine making the numerator larger, so I considered the series |(-10)n|/n, and tried taking the limit as n goes to infinity, but that limit is infinite, isn't it?
Use the ratio test. an = 10^n/(n!). What is an+1/an.
Yeah, you need a series that converges. Keep in mind you don't have to find a series which is greater than the original series for all n; it just has to be greater for n>N where N is some finite number. That's because you can always discard a finite number of terms when testing for convergence. You only care what happens as n goes to infinity.
In this problem, you can see the numerator always increases by a factor of 10, but the bottom grows at a faster rate. What if you compare it to something like k(1/10)n where the top and bottom always change by the same factor? You can set the constant k to whatever you want, since it won't affect the second series' convergence, to make the comparison easier to prove.
If I use the ratio test...|an+1/an|=|((-10)n+1/(n+1)!)/(-10)n/n!|=10/(n+1).
So the limit as n goes to infinity of 10/(n+1) can be found by dividing by n, and taking the limit of the result.
And the limit of n as it goes to infinity of (10/n)/(1+1/n)=0/(1+0)=0.
Since this is less than one, the Ratio Test says that the series (-10)n/n! is absolutely convergent, and therefore convergent.
Is this correct?
Is this correct?
Yes, that's it.
Thank you!
