Determining the coefficient of static and dynamic friction
The discussion focuses on determining the coefficients of static and dynamic friction through experiments with three surfaces: wood, glass, and metal. The static coefficients calculated are 0.762 for wood, 0.324 for glass, and 0.263 for metal, based on the angle at which an object begins to slide. To find the coefficient of dynamic friction, timing the object's descent down an inclined plane is suggested, allowing for the calculation of acceleration. The acceleration can be derived using the equation s = v_0t + (at^2)/2. The urgency of the assignment deadline is emphasized, highlighting the need for clarity on calculating acceleration from timing data.
thestudent101
I have a Mathematics C assignment, with one question being about static and dynamic friction. But I think it fits this forum. Anyway, we need to conduct experiments to show if there is a difference between static and dynamic friction or not with three different surfaces.
The weight of the object being tested is 0.0685kg and gravity has been assumed as -9.8m/s^2
I have calculated the coefficient of static friction for the three surfaces. This was done so by placing an object of weight 0.0685kg on a surface and increasing the angle until the object starts to slide. For wood, the average angle was 37.3°, for glass - 18.0° and for metal - 14.7°. For calculating the static coefficient of friction the weight force has been calculated as
w=mg
w=0.0685*-9.8
w=-0.6713 Newtons
This has then been subbed into
0=wsinθ-Fr
0=-0.6713*sin(37.3)-Fr
Fr= 0.407 Newtons
0=-wcosθ+N
0=-(-0.6713*cos(37.3))+N
N=0.534 Newtons
μ=Fr/N
μ=0.407/0.534
μ=0.762 (wood)
This process has been repeated for glass (μ=0.324) and for metal (μ=0.263)
Now I am completely stuck on how to calculate the coefficient of dynamic friction. I was thinking about timing how long the object takes to slide down a certain length from a set angle? But I don't know how to calculate the coefficient from that? Any ideas and help will be appreciated thanks.
To find the co-efficient of dynamic friction, writing the force equations will be a good way to start. Now, if you time how long the object takes to slide down the plane at a certain angle, you will have all the variables to find the acceleration of the object. Substitute this acceleration into the force equation, from which you get the frictional force, and hence, the coefficient.
Edit : I just realized you have another same thread here. Please don't multiple threads.
This is due tomorrow, I know I've left it to the last minute but hey.
Anyway I understand how to do that, but how do you work out the acceleration from timing it?
Use ##s=v_0t+\frac{at^2}{2}##
  • · Replies 28 ·
