Determining the force that is required
  • Thread starter Thread starter x3lifelove
    Force
The problem involves calculating the force required to perform a specific amount of work over a given displacement, with the force acting at an angle to the direction of displacement. The subject area relates to work and energy in physics.
  • Mathematical reasoning, Problem interpretation
  • Participants discuss the relationship between work, force, and displacement, using the formula W = Fd cos(θ). There is some uncertainty regarding the calculations and units used in the problem.
Some participants have provided calculations and expressed uncertainty about their results. There is acknowledgment of potential errors in unit representation, and participants are reviewing each other's work without reaching a definitive conclusion.
There are indications of confusion regarding units and the setup of the problem, as noted by participants who mention editing their posts for clarity.
x3lifelove
A force acts an angle of 30.0 degrees relatives to the directions of displacement. What force is required to do 9600 J of work over a displacement of 25.0 m?
The solution that i am getting is 443 N of Force, but I'm not sure if i am doing it right though.
If the force is constant, then [itex]W = \mathbf{F} \cdot \mathbf{d}[/itex]. this gives W=Fdcos(30),
9600 Nm = F * 25cos(30) m
F = 443.4 N
jhae2.718 said:
If the force is constant, then [itex]W = F \cdot d[/itex]. this gives W=Fdcos(30),
9600 N = F * 25cos(30) m
F = 443.4 m
Thank you (:
Note I messed up the unit originally, check my edited post. (Writing this on my phone)
Will do! Thank you again !
  • · Replies 38 ·
  • · Replies 18 ·
  • · Replies 35 ·
